Blazer Tank Conversion - Sending Unit Wire
What have you used to wire the new tank behind the rear end. I spliced my original wire but there is too much resistance so it reads "E".
Thx
71 C-20 Custom Camper California Truck |
Re: Blazer Tank Conversion - Sending Unit Wire
With the gauge setup more resistance should make the dash unit read beyond full since "0" ohms = empty and 90 ohms = full.
If you are reading empty then I would suspect that the wire from the tank is grounded to the truck somewhere. Try disconnecting the sender wire at the fuse panel to see if the dash guage reads full with the wire disconnected. Jim Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
That is an easy answer... the gauge does not read full when the wire is disconnected; rather it reads 1/4 tank. Once I hooked up the wire it went to "E".
Gauge Problem?
ttt
Gettin By on Gettin By
Guage is 30 ohms, Sending unit is 90 ohms. Put a 45 or 47 ohm resister *depending on what the parts storr has in stock* inline right before the guage.
Run a search for fuel guage ohm and you should get what you need.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" Last edited by jayharrell; 04-18-2008 at 04:04 AM. |
