Old 04-16-2008, 01:57 AM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
Painting my 205
So im gonna be re-installing my 205 hopefully tomorrow, after I get my adaptor back from the machine shop. I was thinking while i got it out, maybe I should paint it up pretty. How have you guys painted yours? Pics?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 04-16-2008, 02:02 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Painting my 205
I've seen it dun 2 ways recently and they both look good. One guy did it in a cast iron color and the other was chevy orange
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-16-2008, 03:31 AM   #3
jamie72
jamie72's Avatar
Re: Painting my 205
i use high temp chevy orange paint.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-16-2008, 04:00 AM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Painting my 205
I'd go with gray or the cast iron color, orange always seems to look dirtier quicker, and cracks and leaks show up real easy on grays.
Edit: They show up well on flat colors, glossy paint hides leaks.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-16-2008, 04:17 AM   #5
69 COPO
Re: Painting my 205
I have 2 with original paint on. Mine are not chevy orange. I was told they are a chrysler red. Not for sure though. Anyone know for sure let me know.
69 COPO is offline   Reply With Quote
Old 04-16-2008, 05:03 AM   #6
Critter
Future TOTM Winner
Critter's Avatar
Re: Painting my 205
I painted mine with a custom color. It looks like a mixture of engine oil and auto trans fluid. It's really quite unique, I think it is named something like "no-seal brown" Seriously though, I would paint it a high temp semi-gloss black, but thats just my $0.02.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-16-2008, 05:21 AM   #7
PETEM1957
Junior Member
Re: Painting my 205
So, what color are they original just cast iron like the 4 speed trannys are or are they painted?
Anyone have pics of an original setup or brochures of the same?
PETEM1957 is offline   Reply With Quote
Old 04-16-2008, 05:31 AM   #8
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Painting my 205
I read that the origional color of the t-case was red. IMO as long as it is clean, it doesn't matter what color it is. Later, Mario
BLUE THUNDER is offline   Reply With Quote
Old 04-16-2008, 08:23 AM   #9
Mint68
Mint68's Avatar
Re: Painting my 205
Mine looked like it was orange, so I figured it should stay orange. It does stand out because of how they hang down.
Mint68 is offline   Reply With Quote
Old 04-16-2008, 12:29 PM   #10
JimKshortstep4x4
Re: Painting my 205
We paint our 205's red to match the original color which is a rather dark red.
Attached is a picture of my son's Burb frame with the 205 painted red.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-16-2008, 01:18 PM   #11
vtblazer
vtblazer's Avatar
Re: Painting my 205
As far as I know and can tell, this one has never been painted.
Not close up pics but you can see it's orange.
vtblazer is offline   Reply With Quote
Old 04-16-2008, 01:12 PM   #12
Re: Painting my 205
Although the "correct" color is red,I like them Chevy orange if theat`s the motor color.I`d only paint one red if there was other red,like body or motor,or the truck was a correct restoration.Basically,I like black below the body line,but the vitals up in the frame look cool peaking out a bit of orange.Orange helps me want to keep it clean.
Old 04-16-2008, 11:29 PM   #13
Yukon Jack
Yukon Jack's Avatar
Re: Painting my 205
I didn't bother painting my Rockwell before I reinstalled it when I had my 69 torn apart and I'm actually glad I didn't bother.
I did paint my bbc when I had it torn apart and took great care to clean the block very well and used high quality hi-temp engine spray paint (either VHT or Duplicolor) - now a couple years later the paint is already peeling in a number of places on the engine.
For all the effort I took in painting it, I'm really disappointed to see it peel.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-16-2008, 11:36 PM   #14
jaros44sr
jaros44sr's Avatar
Re: Painting my 205
Good point, YJ. Why bother, if the paint ain't gonna stick anyways
SAFETY FIRST
AS usual, off topic
Jim
Old 04-17-2008, 06:02 AM   #15
Musclerodz
Re: Painting my 205
The one is my Blazer I painted Red to match the engine. The K20 customer truck is painted orange to match its motor.
Mike Redpath
Musclerodz is offline   Reply With Quote
