Welp..I cranked my torsion bars....Update!!
It's done.
It dropped 3" Right onto the snubbers ![]() Guess I need to cut the snubbers in half. ![]() I took the bolt all the way down til it was flush with the upper block. Guess if I want it any lower, gonna have to buy drop spindles, or bag it. carry on..! ![]()
Tim Road Hounds Last edited by **grumpy**; 04-21-2008 at 07:31 PM. Reason: update |
Hollister, CA.
![]() Join Date: Sep 2006
Re: Welp..I cranked my torsion bars....
Cool man.....pics ?
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Went to take pics, and batteries were dead! Doh!
Tomorrow.
Tim Road Hounds |
![]() Join Date: Sep 2007
Grumpy,
Tomorrow is today....pic's please... Let see it.. What do you think of it? |
Grumpy,
I don't know if you talked to Eryk or not but here is what my drop looks like.
http://public.fotki.com/fuelpump |
Ok. Finally time to post pics.
I really wanted it lower, but the bars are max low. They're sitting right on the snubbers. ***Can I cut the snubber and mount down to gain another inch???*** Then I went to drop the back some, but if I do, it raises the front some... So..I may have to roll this way until I can gather the remaining airride stuff to bag it. Much improvement over what it looked like when i brought it home 2 weeks ago. ![]()
Tim Road Hounds Last edited by **grumpy**; 04-21-2008 at 07:42 PM. |
Hollister, CA.
So...you haven't cut the snubbers or used longer bolts ??
looks sweet! vast improvement!!
Not yet chief.
How much of the snubber can I cut? It's sitting on that c shaped pad. I figure I can trim that... Or should I just remove it? If I go longer bolts, will it throw the frontend way outta whack??? If I could get another 1 1/2, I'd be ok with that for now. Then drop the back 3" more. I have half the stuff I need for bags, but don't wanna do that til fall.
Tim Road Hounds Last edited by **grumpy**; 04-21-2008 at 08:28 PM. |
![]() Join Date: Aug 2005
looking good!
100% gearhead
Those bump stops are really easy to cut with a sawzall. They also pull out. But now that your torsion bar adjusters are hanging way down, a good and safe idea is to remove them from the control arms and turn them one spline. That puts them back to the stock adjustment and still keeps the truck low. Otherwise they drag on speed bumps, driveways, gas station entrances, etc. Then you could end up finding out the hard way, like I did, that those bolt heads don't last very long and break. Mine broke doing 60 mph and dug into the pavement about an inch and a half. Shot me off the road and gave me a pretty interesting ride!
I understand what you're saying, but...
Those bolts and rear bar mounts are still pretty high off the ground. I have a pretty tall tire. My old 64 had 205/15's, and this has 235/15's. I think even if it drops another 1/2" to 1" up front, and I drop the back 2-3", those bolts are still higher than the mufflers and front c/m. I'm still open to suggestions and opinions. Thanks
Tim Road Hounds |
Grumpy,
Looks Good, I understand the wish for lower. From the looks of your ride height my Burb must be about bottomed out as well cause it's about the same as mine.... "spindles are on the shelf out in the shed....." Let me know if you want them there just hanging out..... Looks good you got a great start there.... Enjoy it.... |
![]() Join Date: Oct 2006
looks very nice!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#15 |
I like the whitewalls , get them from cokers? i think that made more improvement then the drop.
#16 | |
haha. Nope, not this time. They are used radial tires with new Port-a-walls!!! ![]() I've bought at least 12 sets of new $700. radial www's in the last 6 or so years... Being laid-off, went the cheap way. My buddy is a dealer for MooN, so he bought 6 sets of portawalls. I got them from him. I'm going to cut the snubber, then see how much more it drops up front, then adjust the back down some. Alittle too much of a rake for me. Then drive it til I decide to bag it.
Tim Road Hounds |
#17 | |
#18 |
Formed rubber rings that look like wide whitewalls.
you slip the inside 2" inside the bead before you air the tire up, and you have instant www's. i'll look for a pic.
Tim Road Hounds |
#19 | |
#20 |
I've bought new bias-ply www's at about $400+
I've bought way too many sets of radial www's at $700+ These were $80. and I mounted them on a used set of 235/15's So they will serve the purpose for awhile. And no, their not supposed to be used on Radials. But..I've had them on a couple other cars, and they last for 1-2 years, unless you do a ton of highway driving. They look great at 10ft. You can tell they're port-a-walls if you get real close. Suits me fine. ![]() ![]() **Also...Here's a pic of my old 59 Nomad wagon. it had port-a-walls on it for over 2 years, on Radial tires. They would flap pretty bad when I would do 90mph on the highway though ![]() ![]()
Tim Road Hounds |
#21 |
1962 C-10
Looking good! Nice improvement...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#22 |
Tot Roddin'
Looks good!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#23 |
cool, thanks for the info
sweet wagon!!!
#24 |
[/QUOTE] Imperial Kustom. Those bump stops are really easy to cut with a sawzall. They also pull out. But now that your torsion bar adjusters are hanging way down, a good and safe idea is to remove them from the control arms and turn them one spline. That puts them back to the stock adjustment and still keeps the truck low. Otherwise they drag on speed bumps, driveways, gas station entrances, etc. Then you could end up finding out the hard way, like I did, that those bolt heads don't last very long and break. Mine broke doing 60 mph and dug into the pavement about an inch and a half. Shot me off the road and gave me a pretty interesting ride!
Hi Imperial Kustom, Can you tell me how difficult a job it is to remove the torsion bars from the control arms and rotate a spline? Are there any tips for doing the job!? How much will one spline move the arm up? I only have 2.5" clearance at the moment and keep hitting them on speed humps ![]() |
#25 |
Remember that you should really get your alignment checked when you drop this. Specifically you need to make sure that the camber is still set right.
B |
