Old 04-19-2008, 06:03 PM   #1
Burt4x4
Burt4x4's Avatar
Hydro Assist is in>>>
Well this is what I ended up with, so far it works great. Did a test run to Hollister a few weeks back and all is fine. Easy easy steering and no belt slippage or sqeeeling
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-20-2008, 12:14 AM   #2
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Re: Hydro Assist is in>>>
Cool!!!
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 04-20-2008, 12:43 AM   #3
Yukon Jack
Yukon Jack's Avatar
Lookin' great!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-20-2008, 02:11 AM   #4
FormerMember
Sweet... what fluid are you using? I went with Amsoil tractor oil.
FormerMember is offline   Reply With Quote
Old 04-22-2008, 06:20 PM   #5
Burt4x4
Burt4x4's Avatar
I went with Valvoline Syntech PS fluid..Only reason is it was on sale at AutoZone so I thought I would give it a try..so far so good no leaks
Old 04-22-2008, 10:59 PM   #6
OldCreek
OldCreek's Avatar
BTW, how is the ride with that flat 4 leaf spring set up?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 04-23-2008, 04:20 PM   #7
Burt4x4
Burt4x4's Avatar
Thoes are Rancho 4" and they are about 18yrs old The ride has allways been fun heheh I don't have anything to compare them too as that is what I have allways ran.. They seam to work fine..never gave me a reason to swapum out
Old 04-23-2008, 12:32 AM   #8
I am green with envy!!!That`s just beautiful.
Burt,if you don`t mind I need to pick your brain on this set-up for when I get there on my shortbed.I just have the Dana60 and haven`t started with steering.I haven`t even gone through the axle,yet.
Old 04-23-2008, 04:23 PM   #9
Burt4x4
Burt4x4's Avatar
Sure sure, just let me know..I can post up pics of whatever you need..
Here is one:
Old 04-23-2008, 07:27 PM   #10
OldCreek
OldCreek's Avatar
I'm with Special K. Got some questions also. Any problems with clearance with the crossover steering/dana 60/and flat leaf springs? Do you think it would clear with flat leafs without the 4" lift?
Old 04-23-2008, 08:11 PM   #11
Burt4x4
Burt4x4's Avatar
I have no clearence issue now, but I did in the begining. WFO Concepts is were I got my steering arms and x-over links. Trevor @ WFO worked with me week after week to get the right combination of parts to clear my short lift and 454/D60. He and I played package tag until it was right = he would send me parts and I would send back parts, back and forth until I had a working system. Awesome customer service and never asked for an extra dime for all the additional shipping
Anyway I personally think a crossover setup is going to require some sort of lift for the draglink to clear. I am running a HighSteer tierod = above the axel. With stock lift I doubt a highsteer tierod would clear, so the facotry tierod infront of the axel would be used with the crossover, if it will it with no lift???????????
I am no expert on steering geometry, I only know what I learned from my doing my setup....
here is the other side:
Old 04-23-2008, 11:40 PM   #12
That`s just how I want mine...high steer and all.I have 6" EZ-rides.So I`d be good on clearance.
Let`s start with the steering gear.Exactly what one did you use?I tell ya what...Do you think you could list from the steering box to the steering arms exactly who`s what you used???
You did all the R&D on this and I guess a bit of T&A,I mean,T&E(as in trial & error).I know it`s been done before.But,we have the same thing as you,pretty much.
Old 04-24-2008, 12:35 AM   #13
Burt4x4
Burt4x4's Avatar
Ok, well I started with ordering from PSC:
I got the Hydro Assist Kit for crossover, came with ram/hoses & fittings/PS pump & resavior/gear box:
Made me a braket to mount the resavior
WFO originally sent me the arms that put the tierod(highsteer) behind the axel but my BBC oil pan was in the way, see the long double arm on the right.
So here I am trying to make the new arms work that put the tierod infront of the axel, the pitman arm coming off the gear box is too long so the drag link ran into the tierod. See how the tierod is resting on the wood, not lining up with the steering arm ontop of the kingpin.
Ahhh much better with a shorter pitman arm, WFO sent me 4 to pick from and this one did the trick.
Most drag links are bent like this one but due to my short lift this design was not gonna work as well as a stright draglink would.
Straight draglink and highsteer in front of the axel were the two main changes with my setup, well shorter pitman arm too.
The PSC stuff went right in with ease and none of it leaks!
Hope this helps
Old 04-24-2008, 12:39 AM   #14
Burt4x4
Burt4x4's Avatar
http://www.pscmotorsports.com/index....roducts_id=493
Not cheep but well worth the cost
Old 04-24-2008, 12:42 AM   #15
Burt4x4
Burt4x4's Avatar
http://www.wfoconcepts.com/Steering/...HeavyDuty.html
The beauty with working with WFO is Trevor will customize the set up to work with your rig..it not like you buy the kit then your on your own making it work..A++ Customer service...tellum Burt sent you and you want a similar setup
Old 04-24-2008, 03:59 AM   #16
Awesome!I`ll save this for sure.I`ll definately be talking to Trevor.Sounds like a righteous guy.
Old 04-24-2008, 04:20 PM   #17
Burt4x4
Burt4x4's Avatar
Oh ya the WFO arms I posted above eliminate the kingpin spring. Instead of a spring pushing down on the white colar in the kingpin a small stack of shims smashes down when you tighten up the arm to the D60. This completly eliminates "death wobble" or the chance of having it. No springs to deflect so no DW
Old 04-24-2008, 05:36 PM   #18
FormerMember
You know he got rid of the shims now? He has a pre-load set screw now. Mine arms are going back for modification.
Old 04-24-2008, 07:57 PM   #19
Burt4x4
Burt4x4's Avatar
Ya thats right, pretty sweet idea too I haven't seen them yet..other than a photo. My buddy Dillion is getting a set. awesome!
Old 04-25-2008, 01:34 AM   #20
jaros44sr
jaros44sr's Avatar
Cool thread, very informative. Now I have to figure out how to save it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-26-2008, 04:58 AM   #21
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Thats awesome I will have to keep this post in the back of my mind I had wanted to do this awhile ago still no money for it. Don't look like it would be too hard either.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-04-2008, 08:10 PM   #22
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sweet I got my hydro assist from west texas off road works great and turns the front even when locked in.... Your set-up looks killer and im sure you will be happy with it...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
