Wide Eyed User
My Build - Old Blue EyeS
Here are some up date pics:
Just put in the power steering and redid the wiring head to toe... Also have new gauges, and new wheels and rubber... I will post as I can.. BUT I am not as good as some are at taking step pics ![]() before... ![]() ![]() ![]() ![]() ![]() ![]() after to come a bit later have to jet out for a while... ![]()
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
Re: My Build - Old Blue EyeS
looking good!!!
Resistance is Futile
Is that the finished gauge panel in the truck?? Looks cool if it is.........are you building a hybrid low-high hump tranny cover? Good looking project.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I did a instrument cluster kinda like that on a '65 I had years ago. took out the black panel and polished it with a wire wheel. the writing is on the glass, looked pretty cool, wish i had pics
looks to be lowered , what did you do to lower it?
Wide Eyed User
Here are some of the wiring photos:
![]() ![]() ![]() and the New panel is this: ![]() All digital from Dakota Digital. They sent wrong color (green) so it goes back (that's why plastic is still on it), and in a week or so I should have the correct color BLUE. Looks very coo1 ! Original dash will be for sale, in classifieds soon. Wiring turned out to be very easy. Just seprate and do in sections no prob. The power steering add: ![]() ![]() ![]() ![]() ![]() ![]() Not bad for a first timer install. Had custom hoses made (measure fifteen times, cut once, lol). Drilled through fender well and used grommets for neater install). You can see the a little bit of the wiring redone in the engine bay, much neater and no odd wires with no beginning and no end...lol
Wide Eyed User
Final pictures...
of power steering, new ididit steering column. I have a new (old) steering wheel coming as well. But it is coming from Japan, so it may be a while...lol. Very cool, something out of the ordinary. After I took this pic, I did take my plasma cutter to the sheet metal where the steering univeral joint comes through the fender well to open it up a bit! ![]() ![]() Pics of new wheels and tires.... Truck sits on 2.5 inch drop spindles in front and 5 inch dropped springs in rear. Ford nine inch rear end. 4 wheel power disc brakes. (5 on 5). Wheels are American Racing Torquelite 18x8. Tires are Faulken 452 (LMAO! they are Y speed rated - over 184 mph .. like I need that) 255-45/18. Oh yea.. grill is from a 61 obviously even though its a 62. I like the dual headlights ![]() ![]() ![]() Steven
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 04-22-2008 at 07:37 AM. |
Nice build! The power steering did you have to change the arm on it? On mine I kept it the same but I'm still at the frame build.
#9 | |
Wide Eyed User
Only changed the pitman arm. All other geometry remained the same. I have seen some other installs that go through the frame for the gear box install, where mine is notched. Could be the year, could be my amatuer install..lol.. but it all lined up.
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 04-22-2008 at 07:49 AM. |
#10 | |
Wide Eyed User
2.5 inch dropped spindles in front and 5 inch drop springs in rear. very drivable but a few high - speedbumps get the exhaust a bit. Next up is major steam clean, then moving the fuel tank to the rear and possibly putting a wood bed in it (has sheets of plywood now, although it makes for easy access ![]() after that Interior - exterior I like the way it is, although my kids keep telling me to paint it. Then the engine compartment and air. Air could be sooner than later because I live in vegas! Steven
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 04-22-2008 at 09:50 AM. |
looks very sweet!
Wide Eyed User
looks sweet, who did you purchase your wiring harness through, did it give you alot of trouble?
#14 | |
Wide Eyed User
and 25% the cost of most others.... I did see another that might have been worth a few extra bucks, just because of the way some of the circuits are handled and the mounting. Can't remember the brand but it has been mentioned on this site a few times.
#15 | |
#16 | |
Wide Eyed User
#17 |
454 club
good job, new wiring always makes it better
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
#18 |
64-66 CHEVY JUNKIE
NICE,NICE,AND NICE Looks good man!!!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
#19 |
all i can said its i agree broo sweet truck
Fer
1966 chevy c-20 truck " La Chata " under construccion ![]() ![]() ![]() |
#20 |
Wide Eyed User
Thanks!
#21 |
Have you gotten the chance to try out the power steering yet? I went to a quick ratio box and have a similar tire/wheel combo.........turns like its on rails!!!!!!
#22 | |
Wide Eyed User
Oh yaaa.. been driving it around.. we have a Hot Rod nite at a local bar "Hogs and Heifers" tomorrow nite... will be there. In fact drove around to day... what a difference, best thing I did so far!
#23 |
TexasBowhunter
Allsome, truck!
I want your steering wheel! |
#24 |
Very cool!!
I love those wheels!!! I almost went with those,but I bought Coys C5. |
#25 |
![]() Join Date: Apr 2007
![]() ![]() Last edited by 283 Man; 04-30-2008 at 03:58 AM. |
