Bellhousing questions
Does anyone know if I can use the stock 3 speed bellhousing for a 283 motor swap? Also what about lower motor mounts? Can I use the same ones as the 230 that is in it? I plan on changing the upper mounts to new ones but do not know if the part thet bolts to the frame will have to be changed. Also can anyone recomend a good set of headers that will work with my 3 on the tree? Thanks in advance. Dennis
P.S. I will post pics if the swap as soon as I start it |
Re: Bellhousing questions
Well I can tell you that I just got the motor in my 66 today. I swaped a 250 6cyl and installed a 283 v8. I used the all of the 6 cyl stuff bell housing,flywheel, clutch,starter. The rear mounts are the same the front mounts are the same after you remove the extentions for the 6 cyl. The bell has one more mounting hole but the 6 cyl bell works just fine. that way you use your original clutch fork and linkage. I found out all this great info from some very helpfull folks on the website. Hope your engine swap goes a smooth as mine did
#3 | |
![]() Join Date: Oct 2007
Thank you for all the info I knew someone on this site would know the answer. this is the motor I will be putting in minus the bug catcher. It is currently in a T-Bucket and the owner is going to swap it out for a 327
![]() Last edited by dedjr67; 04-23-2008 at 02:17 AM. |
Council of the Elders
I told you so!
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
