Guest
Posts: n/a
antenna mounting problems
anyone have too big of a hole for mounting the antenna? I just cant find one to fit. Anyone have a good repair without welding? It is already painted.
Chasin' the Dream
Re: antenna mounting problems
Here is a pic of my"antenna" lol. Thats all that is there but it works great, even for distant FM stations! Not sure why it works, but have been unable to find a mast to bolt on existing pieces.
Born with a Bowtie ![]() 1971 C/10 350/350 Daily Driver/project Assumption=The mother of all ![]() |
#3 | |
Trueman |
#4 | |
Active Member
![]() Join Date: Jul 2007
I have a cowl that doesn't have an antenna hole and I've been tempted to drill a smaller hole for an antenna. Not sure if I'm going to do that, though. |
its all about the +6 inches
FM still needs an antenna, the unit should not have it contained. I've had too many cars get vandalized with hoodlums ripping the antenna off.... and FM never worked til the mast was replaced. Even in the current rig, my burb, I had to use a test lead wire with alagator clips on the stub on the cowl before I could pick up any stations at all.
You can get repro units to fir the hole perfect, but they aren't cheap. |
Nothing to see here.....
![]() Join Date: Jun 2007
yep, you are going to have to blow around $60 for a new reproduction piece. I tried the auto store antennas, but there are just as you describe. The 2 mounting swivels are too short.
I bought the reproduction and it works AND fits perfectly.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Active Member
68, ask and ye shall receive......
the standard stationary mast: http://www.classicparts.com/prodinfo.asp?number=69-961 and what I got, the telescopic: http://www.classicparts.com/prodinfo.asp?number=69-962 Classic Truck Parts is a site supporter as well.
Active Member
Thanx, tcb-1.
trjohnso, sorry for hijacking your thread... I had forgotten that I needed an antenna until I saw your post. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I bought one for my blazer and all I have to say is lock tite the mast cause someone else always wants it more than you do....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
