Old 04-23-2008, 06:26 AM   #1
tkmad
Rear end options C20
I've got a '67 C20 with an Eaton rear end I believe, correct me if I'm wrong, and it is geared pretty high. I tried to count and I believe it is 4.56. Is there a bolt in swap where I could get 3.73's? A 12 bolt or a dana 60 from a later model I should look for?
Thanks!
Tyler
tkmad is offline   Reply With Quote
Old 04-23-2008, 09:12 AM   #2
sodak69c10
sodak69c10's Avatar
Re: Rear end options C20
are you running a 12-bolt now?
you could change out the ring gearand pinion to 3.73 on most any diff.
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 04-23-2008, 12:27 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no, he has an eaton.
You have coils, or leafs, and do you have any cutting/welding abilitys?
Old 04-23-2008, 01:02 PM   #4
All Eaton HO52s are geared low.The highest gear is 4.10 and a rare 3.90 (not much better).I say high when the ratio is lower.A low gear is a high ratio.
A Dana60 from a GMC will go in pretty directly,maybe brake lines aren`t the same.The highest gear is 3.54.
You can go with a 14-bolt from`73-up.What Longhorn Man was getting at is one shock mount will need moved as well as the spring saddles.If you have a coil rear you`ll also need to change spring saddles and the best bolt-in is that 3.54 Dana60,if you can find one.I guess you can still get a gear set and install in any GM Dana60 from these years.
Old 04-23-2008, 06:39 PM   #5
tkmad
Thanks for the replies. It's got coils and I have some welding ability but I was hoping for a bolt in since I don't have a shop yet and may not for at least a year. Did the GMC dana 60s have the coil springs as well?
Old 04-24-2008, 01:06 AM   #6
Longhorn Man
dana came in both chevy and GMC, and could be had in coil aplication (I have one under my C/20 coil burb with 3.54 gears and a posi)
