04-25-2008, 11:18 AM | #1 |
4x4 power steering on my 2wd 60- Help!
I've just got a power steering box which i thought was from a 1/2 ton 2wd truck. It did'nt come with a pitman arm though and when i looked into getting one i noticed the steering box i have requires a pitman arm with the "clamp" type fitting and NOT the nut type which there usually is. I now believe this box came from a 4x4 and i'm not sure whether i can find a pitman arm to fit it and work with my 60 Panel. Can anybody shed any light on this please
Steve. |
04-25-2008, 01:56 PM | #2 |
Re: 4x4 power steering on my 2wd 60- Help!
If it came from a 4x4 it will not work. A 4x4 box moves in a push, pull motion as a 2 wd box works in a side to side motion.
04-26-2008, 04:48 PM | #3 | |
The 4x4 power steering steering gear box will work for the power steering conversion on your '60 Chevy Panel, you just need the correct pitman arm that will receive the shaft on your power steering gear box. Any Chevy 4x4 with power steering from the late 60's thru the late 80's will work and they are very abundant from the scrap yard or try www.carsteering.com. |
04-26-2008, 07:15 PM | #4 | |
04-26-2008, 10:10 AM | #5 |
Thanks for the reply short step, looks like i will be sticking it on e-bay then! Steve.
04-26-2008, 06:10 PM | #6 |
Hey LILRED66, Thanks for that reply- i better get searching then as these parts ain't easy to come by over here!!! Steve.
04-27-2008, 11:01 AM | #7 |
No worrys 62shortstep, i think i have tracked down the correct pitman arm now- should get it middle of next week. Thanks for the help .
04-29-2008, 05:15 AM | #8 |
not trying to hijack, but will a 3/4 ton power gear from a mid '70s truck work?
CHEVY ONLY |
05-08-2008, 08:02 PM | #9 |
^^^^anyone know??
CHEVY ONLY |
05-08-2008, 11:30 PM | #10 |
Council of the Elders
Was just strolling the local u-pull it the other day and I would bet your life they are the same!
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
05-08-2008, 09:34 PM | #11 |
re: 3/4 ton gear: I've never asked the question when I purchased one, so I would assume that they would work.
as a suggestion, check the part# for autozone/napa/advance etc., for both 1/2 and 3/4 ton |
05-09-2008, 12:10 AM | #12 |
cool, thanks guys
CHEVY ONLY |
