Old 04-29-2008, 07:07 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Wink fuel tank
does anyone know what the largest fuel tank that will fit in the stock location under the back of these burbs is? I don't care if its aftermarket or one you can get at the junkyard. I wouldn't mind even doing a little cutting and fabricating to make it fit. Mine is all beat up and the straps are rusting through, not to mention the fuel gauge doesn't work, so my tank will need replacing soon. Thanks.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 04-30-2008, 01:26 AM   #2
72 sub
72 sub's Avatar
Re: fuel tank
Mine had a crazy homemade one in it when i got it but it hung down too low.I got one out of a Jeep cheroke, it fit between the rails perfect.I think they come in two sizes.
If you get lost, come back and tell me where you are. 72 Burb, 86 1 ton crew cab dually.
72 sub is offline   Reply With Quote
Old 04-30-2008, 04:23 AM   #3
Angelo
Re: fuel tank
My 72 Suburban has a 55 gallon tank. The previous owner made it.
Angelo is offline   Reply With Quote
Old 04-30-2008, 05:23 PM   #4
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: fuel tank
a 55 gallon would be perfect! Looks like I will have to get one custom made then.
Old 04-30-2008, 10:45 PM   #5
muscletrucks
muscletrucks's Avatar
Re: fuel tank
At $ 4.00 a gallon......... $ 220.00 ouch
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 05-09-2008, 10:56 PM   #6
wagonhoe
wagonhoe's Avatar
Re: fuel tank
ditto that...
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around
1968 C10 Suburban, 350cid, 700R4, bent frame
1968 C20 Suburban, no motor, trans or interior (SOLD!)
1953 Packard Ambulance
1992 Caprice wagon
wagonhoe is offline   Reply With Quote
Old 05-10-2008, 04:03 AM   #7
IAFF2407
IAFF2407's Avatar
Re: fuel tank
I will have one for sale, out of a '76 Burb, 40 gal. with the sending unit. no straps. this is the one that someone did a build thread on. Pm me if you're interseted and I'll get back to you when I'm back home Monday.
Al
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 05-11-2008, 03:19 AM   #8
TyJ
TyJ's Avatar
Re: fuel tank
I am putting an ECE 27 gallon tank in my sub, have to move the rear crossmember though... kinda spendy but super nice, all stainless, sits up between frame rails, all baffled
55 gallons at 8.5 lbs a gallon is a lot of weight to carry around seems like, might hurt your gas mileage pretty good?
72 K20 Suburban 6.0L, 4L80, 4Wheel Disc Brakes, Hydroboost, In a Million Pieces(edit) A little closer to done
TyJ is offline   Reply With Quote
Old 05-12-2008, 07:06 AM   #9
Brad
Out of the carpool lane.
Brad's Avatar
Re: fuel tank
Blue'72 has a 40 gal tank that I don't think he'll be using. I could get it as far south as Medford if you two would be interested.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 05-15-2008, 07:22 PM   #10
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: fuel tank
thanks guys for the replies. Not going to start this project just yet, but will let you know if something changes.
