Old 11-03-2002, 05:14 PM   #1
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
5x4.75 axles
Anyone know of axles available for a '69 Stepside 12-bolt with the 5 on 4.75 lug pattern? I wanna put the new Salt Flat rims by AR on my truck, and I want 16x8's on the rear. the closest lug pattern they make them is the 5x4.75" pattern. Any thoughts or leads?
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 11-03-2002, 06:04 PM   #2
guitarman
Do it well or don't do it
guitarman's Avatar
I'm assuming you have 6 lug wheels on your truck now. If so your can put 5 on 5" off of a later truck if you make some spacers 3/4" thick to go between the brake backing plates and the end of the housing. I made mine out of T-6 aluminum and they work just fine.
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
Old 11-03-2002, 06:46 PM   #3
crazy longhorn
Fabricate till you "puke"
The truck 5 lug is a 5 on 5 pattern, to get a 5x 4 3/4, you might talk with a machine spob for redrilling axles & drums.....Im not sure about drilling the front rotors .......maybe somebody has this info. good luck.....crazy AL
crazy longhorn is offline   Reply With Quote
Old 11-03-2002, 06:52 PM   #4
mikep
Used to have a truck
mikep's Avatar
Ive had a lot of work done by Dutchman motorsports in Portland , Oregon . They do a lot of mail order work and make custom axles as well as redrilling rotors, axles and drums. http://www.dutchmanms.com/ . They will redrill drums and rotors for $25 a pop . At least that was their price the last time I had some done.
No truck :-(
mikep is offline   Reply With Quote
Old 11-03-2002, 11:22 PM   #5
turmoline
I re-drilled my 6- lug axles to accept the 5-4.75. That bolt pattern actually set up better than the 5 on 5. I did mine for rear wheel discs. In order to press the new lugs though there is an uneven surface towards the inside of the axle that needs to be machined so that you have a nice flat to locate the lugs. I don't know your measurements on those wheels, but I had to machine the center hub and the major outside diameter to accept the rotors as well.
turmoline is offline   Reply With Quote
