Old 04-30-2008, 12:34 AM   #1
superchevy
Got big-block?
superchevy's Avatar
solved the big block into a 67-72 4x4 clearance issue!
LOL!
I bought this '72 GMC a couple of months ago...take a look at what the PO did to get clearance for the 454 swap! See anything missing? SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 04-30-2008, 01:40 AM   #2
jamie72
jamie72's Avatar
Re: solved the big block into a 67-72 4x4 clearance issue!
about half the front crossmember..lol
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-30-2008, 02:00 AM   #3
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
WOW!! Solved that problem, didnt it!!! LOL!!
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 04-30-2008, 02:25 AM   #4
superchevy
Got big-block?
superchevy's Avatar
Yeah, lol, I was shocked when I looked up under there. I think I'm going to put in one of those custom crossmembers from DIY4x4.
SC
build thread
build thread
Old 04-30-2008, 02:34 AM   #5
FormerMember
Heh, tell Kert I sent you. I love mine.
Had to service the oil pan, was very sweet to do.
FormerMember is offline   Reply With Quote
Old 04-30-2008, 09:02 AM   #6
Critter
Future TOTM Winner
Critter's Avatar
Wow! Somebody was asking for their frame to collapse!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-30-2008, 10:14 AM   #7
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Somebody had a massive brain fart when they did that.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 04-30-2008, 01:40 PM   #8
Blazer1970
Blazer1970's Avatar
ignore this
Blazer1970 is offline   Reply With Quote
Old 04-30-2008, 05:51 PM   #9
Burt4x4
Burt4x4's Avatar
hahahaa
I bet the whole front of that truck does this when you rap on the engine
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-30-2008, 06:14 PM   #10
Blue_71
Bloo
Blue_71's Avatar
on the risk of being stupid, would that really be that bad of an idea if a square tubing brace was made to wrap under and welded/bolted on each side, to reinforce it?
like this:
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 04-30-2008, 06:41 PM   #11
Burt4x4
Burt4x4's Avatar
You could do that and would work too Grade 8 and some good welds. Make it removable for easy pan removal too
Old 04-30-2008, 07:11 PM   #12
Blue_71
Bloo
Blue_71's Avatar
thats what i was thinking i know id like mine to be removable to get the pan off... stupid oil pan gasket is leaking with only 1200 miles on the engine
1989 Chevy K2500
Old 04-30-2008, 07:25 PM   #13
Yukon Jack
Yukon Jack's Avatar
I've got my 69's crossmember out at the present time to have it modified to give me the needed oil pan clearance. I'm going to cut it at that same level and have material welded in to allow the bottom portion to be dropped about 1". I hadn't considered doing it like pictured above with bolts securing tubing but that sure could be a good way to do it too. I'm not sure having that area removable would actually allow you to drop and remove the oil pan. Maybe if you could tilt the oil pan enough it would come out, but the crossmember is awfully close to the side of the oil pan at that location and of course the oil pan is quite a bit wider up top where it bolts to the engine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-02-2008, 02:47 PM   #14
vtblazer
vtblazer's Avatar
Bought a 4x4 with a 396 in it once and the x-member was cut like that 'cept they took it to the next level.
Used some 1" square stock tubing as a spacer and welded it all back together.
Better than nothing for sure but still pretty scary.
vtblazer is offline   Reply With Quote
Old 05-03-2008, 04:03 PM   #15
c502
c502's Avatar
I had to modify the DIY4X crossmember a bunch to make it fit the BB truck pan.
big blocks=life
c502 is offline   Reply With Quote
