Old 04-30-2008, 04:50 PM   #1
Rippin-J
OurLadyofBlessedAccelerat ion
Rippin-J's Avatar
Clearance issues on air cleaner for 396
I just replaced my Quadrajunk with a Holley Street Avenger. however I had to use an adapter to get it to bolt up correctly with my 396 which means I lost some clearance with the hood.
I need to locate a low profile or an air assembly that sits recessed around the carb.
Any help on recommended replacements would be great!
Thanks!
_______________________________________________
1968 Chevy C-20 w/ 396
1997 HD Sportster 1200 street tracker
1994 Chevy 1500 Silverado
Rippin-J is offline   Reply With Quote
Old 04-30-2008, 07:17 PM   #2
steelhorse
steelhorse's Avatar
Re: Clearance issues on air cleaner for 396
Is it an open type air cleaner, if so you could try a smaller filter
steelhorse is offline   Reply With Quote
Old 04-30-2008, 07:26 PM   #3
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
I am running the avenger on a 350,with a edelbrock air cleaner. It seems to sit a little lower than some.You will like the avenger,mine worked great out of the box.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 04-30-2008, 08:43 PM   #4
deputyd_0803
deputyd_0803's Avatar
I am running an Edelbrock 650 cfm with the adaptor plate on a raised Edelbrock intake. All on my 402 bbc. I don't have any clearance problems.
deputyd_0803 is offline   Reply With Quote
Old 05-01-2008, 12:48 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i highly doubt you'll have issues... have you tried closing the hood, or measured your hood clearance w/out the stud?
Old 05-01-2008, 01:27 AM   #6
john
member #16
john's Avatar
They do make dropped air cleaner bases.
http://store.summitracing.com/egnsea...115+4294755992
john is offline   Reply With Quote
Old 05-01-2008, 07:11 AM   #7
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Stand an empty small paper coffee cup on the air cleaner and let the hood down slow and easy. It will mash the cup if too low.
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 08-05-2008, 01:05 PM   #8
Rippin-J
Rippin-J's Avatar
thanks for the links, input, and suggestions. Definitely a clearance issue (no question) so may try to go with a smaller filter, then opt for the recessed option available through Summit....
much appreciated.
