Old 05-02-2008, 03:42 AM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
WTB, Adj. Panhard Bar
I need a Adj. Panhard Bar for the 67 Stepper I'm working on, It has 5" Drop Springs in the Back, I Really Don't want to have to buy another New One..........
Reply in Post...........
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 05-07-2008, 03:04 AM   #2
toomanytoyz
Luv the Crewcabs
Re: WTB, Adj. Panhard Bar
ttt
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 05-07-2008, 04:29 AM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
If your going with 5" drop coils, you should really go with a super track bar. Just bought mine from ECE for $109.00 plus shipping ($129). To keep everything in check, 1"-2" drop use the stock bar, 3"-4" drop use an adjustable panhard bar, 5"-6" drop use a super track bar. Good Luck, Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 05-07-2008, 04:36 AM   #4
toomanytoyz
Luv the Crewcabs
Harry,
Thanks for the Tip, I have 5" Coils in it Now & am Seriouly considering using some 2" Spacers that i Have to Get the Rear Down a Little More Level withg the front. If I go that Route I will have to look at a C notch for the Rear then, Any Recomendations on That?
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 05-07-2008, 05:25 AM   #5
myoldchevytruck
Rick,
From what I have learned about lowering our trucks is that when we stay within the normal limits; a mild drop, and the right wheels and tires - Our trucks look good. Now when we go a little more extreme, things start to change a bit. I am sitting on 6 " drop coils (from GMCPauls) and the Super Track Bar (from ECE). Still deciding on tire size but will keep the 15's. No C-Notch needed for my drop but you will probably need to notch yours for that 7" drop and will need to watch the cross member because your drive shaft will be running very close. Either modify your existing cross member or get a drop member to get the clearance. Also consider your exhaust. If your pipes are running under the cross member, you may also look at re-directing them. Lots of board members have run their pipes through the cross member for that ultimate clearance. As you can see Rick, there's allot to consider when Dropping Your Truck but when done correctly, They Look Sweet. That's about all I know. Good Luck, Search previous threads on dropping your truck and ask questions. These board members have a world of knowledge. If your thinking about it - chances are, one of our board members has already done it. Thanks, Harry
Harry
3/6 Drop
Krue's FAQ Page
Vendors
