Old 05-06-2008, 02:27 AM   #1
calvinator
calvinator's Avatar
swapped 73-87 discs, wheels tilted!
I recently removed my 6 lug drum brakes and replaced them with 5 lug discs from an 84 gmc parts truck. I kept all the original parts on my 1970 (crossmember, upper and lower A arms, steering linkages, tie rods, etc) EXCEPT for new 73-87 upper/lower ball joints and of course the 73-87 spindle/disc. I bolted the wheels on to push the truck out and noticed the wheels are tilted in a lot. The top of the wheels need to be pulled in. I notced there are probably 3/4" of shims behind each of the upper A arms, can I just start removing a few of those until the wheels are straight? Ive been told that I should use inner/out tie rods and/or drag link from the 73-87 truck. Are these parts any different? To all you who have done this setup before, have you run into this problem with the camber of the wheels? How'd you fix it?
calvinator is offline   Reply With Quote
