Old 05-07-2008, 05:12 PM   #1
rscam
Were GMC leaf springs an option?
I have heard that GMC had leafsprings standard and you could option for coil overs. Chevy was the other way. I have a 69 GMC and the spid says under the options G70 for leaf springs. Can someone more learned than me explain this?
rscam is offline   Reply With Quote
Old 05-07-2008, 06:17 PM   #2
bigblockV6
Re: Were GMC leaf springs an option?
From 1963-68 GMC did not offer rear coil spring suspension, they actually didn't like the way it worked because suspension travel was limited. By 1969 rear coils were available again but this was due to some GMC trucks and all suburbans were being produced by Chevrolet.
bigblockV6 is offline   Reply With Quote
Old 05-07-2008, 08:24 PM   #3
rscam
So if Chevy built the truck they may have been thinking option for leaf springs instead of standard. That may explain the option code on the SPID.
Old 05-07-2008, 10:04 PM   #4
bigblockV6
Just for curiosity which assembly plant was your truck built? Check for these letter codes in your VIN: F,Z,P,S,J for starters.
Old 05-07-2008, 08:27 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
G70 was a suspension package.2000 lb (each) leafs,12x2 1/2 brakes,HD shocks, 4.56 Dana rear (with certain engine/trans combos).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-07-2008, 09:55 PM   #6
rscam
Another ? then. Why would that option be on a shortbed stepside. Seems like that would be a 3/4 ton option. The spid and the cab have the same vin. on them. I am going to go look at the frame and see if it matches the vin.
Old 05-07-2008, 11:23 PM   #7
StingRay
StingRay's Avatar
In Canada all 67-72 Chev and GMC were typically coil but could be optioned either way.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-07-2008, 11:40 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
69 was an odd year, coils were standard on 1/2 ton GMCs. I have a paper somewhere that I have posted a few times on here that shows this as fact.
Old 05-07-2008, 11:44 PM   #9
Blazer1970
Blazer1970's Avatar
After reading many posts and threads on this subject, I am convinced that
all the '67 - '72 2wd half ton trucks (GMC and Chevy) came with coil springs standard. Leaf springs were an option as your SPID shows.
Blazer1970 is offline   Reply With Quote
Old 05-08-2008, 06:04 AM   #10
bigblockV6
Wrong!!!!! Other than GMC suburbans that were built by Chevrolet starting in 1967, 67-68 GMC pickup trucks came standard with leaf springs, rear coils were not available according to all the factory GMC literature, I never seen a 67-68 GMC with rear coils as well .
Old 05-08-2008, 06:15 AM   #11
bigblockV6
That excludes 67-68 Canadian built GMC trucks they were built by
Old 05-08-2008, 01:55 AM   #12
68350
68350's Avatar
GMCs were ALMOST all leaf springs, however it was still an option. The coil was standard, just not par for gmc trucks.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 05-08-2008, 02:13 AM   #13
ed2552
ed2552's Avatar
It was prolly a heavy duty package for the half ton vs the three quarter ton
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 05-08-2008, 02:26 AM   #14
WorkinLonghorn
Don't know why it was on a C10 but here's the C20 info in case nobody believes anything I say;
Old 05-08-2008, 02:36 AM   #15
rscam
Engine is long gone but it was a 6cyl because of the vin. and 3.73 rear end, but according to that document it should have had a 4.56 rear. Its says 250,292,307 and 350 engines would have 4.56 gears. If I read it correctly
Old 05-08-2008, 02:38 AM   #16
rscam
Also it has the 11" brakes. I suppose someone could have switched the rear axle. Does the axle have the vin like the frame,cab and SPID?
Old 05-08-2008, 02:45 AM   #17
WorkinLonghorn
So does the frame VIN match the cab's?-or did I miss that post?
Old 05-08-2008, 02:53 AM   #18
Longhorn Man
your GMC is a 1/2 ton. 3.73 is the base gear ratio for all 3 speed manual shift 1/2 ton trucks if memory serves... 4.56 is the base gear ratio for all 3 speed manual shift trucks in 3/4 ton.
Old 05-08-2008, 03:57 AM   #19
rscam
C S 1 0C-1 A is the vin. 2wd 6cyl 1/2 ton fenderside. The GMCpauls gmc data dosen't list 1 for a plant but the Chevy data says 1 is Oshawa. where ever Oshawa is.
Old 05-08-2008, 04:05 AM   #20
rscam
Also the vin matches on the frame, cab and Spid.
Old 05-08-2008, 04:26 AM   #21
Longhorn Man
GMC decodes differantly than chevy, look here; (69 only, other years differ)
Old 05-08-2008, 06:27 AM   #22
Longhorn Man
Old 05-08-2008, 08:59 AM   #23
togriff
I've always heard that GMC all had leafs, and chevy had coils. But chevy also had leafs on the heave half tons , and leafs on larger trucks. I've never seen a GMC with coils. I've had alot of these trucks and still do, but I do have a Chevy 1/2 ton with leafs.
72 chevy swb wide project
67 swb stepside project
2007 Dodge ram 4x4
2004 Camry
togriff is offline   Reply With Quote
Old 07-28-2008, 12:56 AM   #24
67_C-30
I have a radical idea!
67_C-30's Avatar
I have had 2 GMC trucks that came with coils - a '69 and a '72. It does not list coils on the SPID, but every GMC with leafs I have, a '69, '70, and a '71 all have Leaf Springs listed on the SPID as an option... I also have a '67 3/4 ton, but it doesn't have a SPID, and looks like it never did. (original paint on the glove box door, no glue residue or scratching?)
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-08-2008, 12:45 PM   #25
Longhorn Man
there is no such thing as a heavy half untill the late 70's and by then they were all leaf.
