05-10-2008, 07:56 AM | #1 |
flip kit gone way wrong!!! need help!!
i flipped a 1976 chevy 1/2 ton truck over the leafs and i can't figure out why the drivers side shock won't stop bottoming out. i used the stock shocks at first and then i when and measured and got a shorter shock. the passenger side is just fine. i think it's because of the way the original shock locations are. i have the 1/2 ton 5 leaf pac i believe. will drop shocks work or will i end up in the same spot? please give me feedback toward a remedy? thanks in advance. still love my chevy even though it rides like a brick.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
05-10-2008, 01:19 PM | #2 |
67-72 parts collector,…
Re: flip kit gone way wrong!!! need help!!
Please post a picture to help us understand. Also,... did you remove the factory bumpstop and metal frame bracket?
05-10-2008, 04:36 PM | #3 |
Pics would help. Did your flip kit come w/some shock extenders?
05-11-2008, 05:48 AM | #4 |
i got the shock extenders today and will be removing the bump stops and puttinh the djm bump stops in. i think those are the major issue( or at least i hope, because i've never heard of any problems like this one. i'll post pics before and after i install( hopefully after all is cured)
05-12-2008, 02:11 AM | #5 |
05-12-2008, 02:13 AM | #6 |
05-12-2008, 11:48 AM | #7 |
It Is What It Is,,,,
Nice work man,,,,
How well did you "enjoy" removing those OE bump stops?
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
05-13-2008, 07:01 AM | #8 |
it was easy. i didnt have a problem at all. i just heated the rivets with a torch until they were cherry red and then used a impact chisel to knock them off. after that i used an impact punch to knock them out. it took less than 5 minutes per bump stop. organization makes it go smoothly. they came off so clean
05-16-2008, 12:40 AM | #9 |
i guess i wont be waiting on 2 inch spindles since they don't make them. why dont they make them? i guess i have to go 2.5 spindles. 1/2 inch lower isn't going to hurt anything but the ants!
05-16-2008, 12:51 AM | #10 |
One day...
Nope slam it!! Looks good man
