Old 05-11-2008, 06:38 AM   #1
rick0312
rick0312's Avatar
clutch?
I am at the point in my build where i need to make a decision on a clutch. i am running 3 speed saginaw behind a 350. My original clutch was very hard on my leg. I was wondering if there is a manual clutch setup that is designed to be easier on the driver?
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 05-11-2008, 08:18 AM   #2
ChevyMex
ChevyMex's Avatar
Re: clutch?
I think late models have hydraulic clutchs, you maybe interested to adapt one to your truck...
Mine is not that hard..
Good luck
ChevyMex is offline   Reply With Quote
Old 05-11-2008, 08:47 AM   #3
89 crew
Re: clutch?
You have two choices for a manual linkage clutch. You can either use a diaphragm cover, or you can get a regular cover made custom to your needs. The diaphragm , any auto parts store should be able to get. It will be easier to push than a typical finger style. The custom cover it takes a clutch shop that knows what they are doing! If you were in k.c. I would send you to Casper brake and clutch. They Are GOOD! What ever you need they can build!
89 crew is offline   Reply With Quote
Old 05-11-2008, 10:59 PM   #4
Wrenchbender Ret
Re: clutch?
89C has it right. Be shure to use a diaphram style clutch. Do not get a reman. You never know what you are going to get. I get the complete clutch kit new from Carquest & they have a great, smooth , soft feel to them
Wrenchbender Ret is offline   Reply With Quote
Old 05-12-2008, 05:36 AM   #5
rick0312
rick0312's Avatar
Re: clutch?
thanks I'll go new and a diaphram!
Old 05-12-2008, 09:14 AM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
Re: clutch?
And lube everything including the peddle shaft,"Z-bar" etc. Also switch to a lighter return spring.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-12-2008, 05:42 PM   #7
rick0312
rick0312's Avatar
Re: clutch?
any idea of where i can purchase a lighter return spring?
Old 05-12-2008, 06:25 PM   #8
WorkinLonghorn
Re: clutch?
I think I got mine from OSH. If I recall,they had a very nice selection of springs there.
Old 05-13-2008, 04:21 AM   #9
rick0312
rick0312's Avatar
Re: clutch?
thanks I'll check them out.
