Old 05-13-2008, 04:24 AM   #1
GM72K10
Next!
GM72K10's Avatar
Clutch neutral safety switch installation
Ok, its been a while since I took the K30 dually apart and its back together on its new frame running again. Before I break this thing a second time, how exactly should this be attached? thanks in advance
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 05-18-2008, 07:53 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: Clutch neutral safety switch installation
So no one has a stick shift truck?
86 K30 CUCV M1028A1
Old 05-19-2008, 06:04 AM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I was wondering how this truck was coming along! I just checked my '84. I had to remove the plastic and metal lower column cover panels to see it. There's a bracket next to the column that the switch bolts to. It uses a plastic bolt and nut to hold it on and the switch goes on the inside of the bracket next to the column. The J shaped rod should be turned up when installed. I'll try to get a pic of it tomorrow.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-19-2008, 02:11 PM   #4
GM72K10
Next!
GM72K10's Avatar
Thanks!
86 K30 CUCV M1028A1
