Pat
rear view mirror
does the rear view mirror for a 69 chev mount on the ceiling or window?
thanx |
its all about the +6 inches
Re: rear view mirror
if it was so optioned, it would go on the ceiling.. 72 was the first year for the glue on kind.
Pat
are their 3 mounting holse on the ceiling?
Nothing to see here.....
![]() Join Date: Jun 2007
Only if, like Andy said, it was optioned with it. I don't believe there's even "pilot dimples" to use as a guide.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Yes 3 screws w/ cover over the joint.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Pat
so on my ceiling it only has one screw hole and it had a window mounted mirror, and its a 69. so would it not have come with a rear veiw mirror out of the factory?
is it listed on your option list?
![]() Join Date: Dec 2006
Here's my orig. '69.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
My '69 has a mount with 3 screws in it. It doesn't have the fancy cover like the above pic
![]() ![]() 400sb-350 crank 400 destroker!!! 377 2.02 dart pro1 alum.heads msd, holley db hooker pro-comps-3in exh. 3 spd. saginaw-3.73posi Flat Bed...want Reg bed...trades? |
Tot Roddin'
Maybe it has come off over the years, but I don't recall seeing one without a cover.
Side note... cobb_ben I was in your area for work on Tuesday.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
