05-15-2008, 03:54 PM | #1 |
pinging
If i put anything but the most expensive fuel in my truck it knocks like a cop at a house party and with the good stuff she runs smooth as silk.
I have been told that my timing is off. I have absolutely NO experience or knowledge about timing. I know there is a GURU out there that can brake it down for me. Why would timing effect the type of gas i can use? What is happening when an engine knocks? How do i fix it so i can put the "cheap" stuff in?
JG If you can't find it at the junk yard you don't need it. |
05-15-2008, 04:21 PM | #2 |
Re: pinging
Retard the timming till it doesnt ping.
The textbook definition of knock is this: “The explosive spontaneous ignition of fuel-air mixture ahead of the normal propagating flame and the subsequent cylinder pressure oscillations in homogeneous-charge spark ignition engines.” Otherwords... its firing when its not suposed to. Adjusting the timming retarded or advanced controls when the plugs fire.. Try settin it at around 10 degrees and see what happens. To do this.. loosen the distributer hold down, so the distributer can be turned but still kinda snug. disconect your advance. point your timming light at the marks and set it where you want it.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. Last edited by spudz; 05-15-2008 at 04:32 PM. |
05-15-2008, 04:33 PM | #3 | |
Re: pinging
What is the timing supposed to be at? Is there a reason the timing would have been advanced? Like was it tuned to run premium? Will there be negative effects to retarding the timing? How do i retard the timing?
05-15-2008, 04:36 PM | #4 |
Re: pinging
well you can have the timing more advanced with premium. So it was prolly tuned to run it.. It would make a little more power like that and be a little more responsive. BUT you can burn a piston leaving it like it is.. pinging is bad for your engine.. SO if you are going to run regular... Retard your timing some.. I added to my first post later. lol sorry for that.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
05-15-2008, 04:46 PM | #5 |
Re: pinging
i have only been running premium...I ran one tank with the cheap stuff but the pinging was pretty bad, i ended up adding octane booster to try to stop it.
05-15-2008, 04:53 PM | #6 |
Re: pinging
I was having the same problem with my '80. If I put the cheap stuff in I got some noises when under heavy load and it would diesel every once in a while. The past two trips to the gas station I put premium in and the problems went away and I picked up 2mpg. Im going to see if I can borrow a timing light this weekend and get it fixed up.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
05-15-2008, 04:49 PM | #7 | |
Re: pinging
http://67-72chevytrucks.com/vboard/s...d.php?t=290498
- Greg |
05-15-2008, 05:41 PM | #8 | |
Re: pinging
05-17-2008, 04:28 AM | #9 |
Re: pinging
Exactly when does it ping? Full-throttle only? Part-throttle?
05-17-2008, 04:24 PM | #10 | |
Re: pinging
The FAQ that billla wrote is far more comprehensive. It goes into great detail about how to achive "optimum" results. With daily drivers, many/most guys are just not going to go through all of that. The problem is, simply taking out some of the initial timing (turning the distributor) may not even help. It just depends upon where it is right now. If it is advanced, pulling it back some will probably fix it. If it is set right, there are deeper issues, simply retarding may not help. As far as negatives, yes there are some. If you retard the timing (and it solves the ping) you have given up some performance. It is up to you to decide how much and if you can live with it. You may lose some fuel milage, but probably not enough to justify the cost of premium? Last edited by LONGHAIR; 05-17-2008 at 04:28 PM. |
05-17-2008, 05:28 PM | #11 | |
Re: pinging
When retarding the timing do i need a timing light? Or can i just back it up a couple of degrees?
05-17-2008, 06:51 PM | #12 |
On a budget like Fred Sanford
Re: pinging
You really need to get a timing light and check to see how much advance you're running. Everything is pure speculation until you verify where it's actually set right now.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
05-17-2008, 05:26 PM | #13 |
Re: pinging
Part throttle just above cruzing....mild acceleration. If i open it up it pings on the way up then it stops at full throttle or pretty close.
Keep in mind that i get absolutely NO ping when running premium.
05-17-2008, 07:12 PM | #14 |
Re: pinging
Sounds like too much vacuum advance. Retarding the base timing would just be a bandaid at best. I agree, you really need a timing light to see exactly what is going on. Have you made any changes to the engine? Carb or distributor?
- Greg |
05-17-2008, 07:26 PM | #15 |
Re: pinging
I just put on an edelbrock 600cfm manual choke, new plug wires and plugs. But the problem was present with the old carb as well.
05-17-2008, 08:24 PM | #16 | ||
Re: pinging
There could be other factors: 1)Where is the vacuum advance connected? Ported or Full? If your distributor was originally made to run with ported vacuum, just the act of connecting it to full vacuum could cause this. (higher octane would mask this) I am assuming by your name that we are talking about an '82 model truck here? 2)Jetting? A lean condition can exaggerate this, where the higher octane was covering it. 3)Engine running temp. Higher cylinder/head temps can make this worse too. 4) Believe it or not, gear ratio. Exceptionally high gears make for a greater load on the engine. It is getting less help (torque multiplication) from gearing, so it "sees" a higher load. This can include taller tires with the same gears. 5)Weight, the actual weight and rolling resistance of the truck is a factor too. Extra weight in the bed can make it worse. Any combination of these factors could be "covered" by higher octane fuel and it wouldn't take much. If you are "right on the edge" with the higher octane, you would never know, until you drop the octane. Yes, you really do need a timing light, "a couple of degrees" is very hard to do. Even if you could, you still don't know where you are. Last edited by LONGHAIR; 05-17-2008 at 08:27 PM. Reason: typo |
05-20-2008, 05:18 PM | #17 |
Re: pinging
1)How do i know if i have ported or full vacuum advance?
2)Jetting...pings with both carbs q-jet and new edelbrock...i would asume if the q-jet was lean the edelbrock would solve this. 3)My engine has no t-stat so cooling system is running on full at all times. Before i switched to my electric fan the engine rarely broke 170...now it stays between 170-180. the pinging was present before and after the change. 4) Gear ratio...no clue what mine is....i have a 3 speed auto...that is about all i can tell you. 5) I keep my bed pretty much empty...unless i have my bike in there. Every time i have moved the bikes i have been running premium fuel and i have not had any pinging.
05-22-2008, 02:19 AM | #18 |
Re: pinging
That is as simple as pulling the vacuum line off of the distributor while the engine is running. If you have "full" vac, there will be a change in the idle. The idle speed will drop from loss of advance and from the vacuum leak you just introduced. With "ported" vacuum..........nothing happens. I would bet that yours is "ported", but simply switching to "full" vacuum with-out any other changes probably will not "fix" it. That will probably bring on new issues, fixable, but different. 2)Jetting...pings with both carbs q-jet and new edelbrock...i would asume if the q-jet was lean the edelbrock would solve this. Not necessarily. 3)My engine has no t-stat so cooling system is running on full at all times. Before i switched to my electric fan the engine rarely broke 170...now it stays between 170-180. the pinging was present before and after the change. Even if it has no bearing in this pinging issue, I would put a thermostat back in. That can cause overheating. But the heat I was really refering to is in the combustion area. If the timing is too late at low speed (idle and just off idle) it creates a lot of heat in the heads and exhaust manifolds. Then when the timing starts advancing as RPM increases, you get pinging. 4) Gear ratio...no clue what mine is....i have a 3 speed auto...that is about all i can tell you. In the 80s, gearing was usually pretty high, which adds to this problem. 5) I keep my bed pretty much empty...unless i have my bike in there. Every time i have moved the bikes i have been running premium fuel and i have not had any pinging. 05-17-2008 08:24 PM Added weight can always make the problem worse. |
05-22-2008, 07:58 PM | #19 |
Re: pinging
longhair,
Lastnight before i read this i switched the vacuum line from the distributer to the full vacuum side of the carb and the idle went up...not a ton but it did change. This morning I stopped and got some 89 octane gas...I'm waiting to see if it starts pinging or not. If it doesn't, does that mean the problem is solved or is the more i should do?
05-22-2008, 08:20 PM | #20 |
Re: pinging
It depends on what you want. The ignition timing affects overall drivability - power, economy, emissions, etc. If you are okay with no pinging with 89 octane fuel, then call it a day. If you are more anal and want to optimize your timing curve for the best performance and efficiency, then you need to go back and read the FAQ link I posted. It's really not that complicated to set it up correctly and it would probably save you a bunch of gas $$ .
- Greg |
05-22-2008, 11:07 PM | #21 |
Re: pinging
I see what your saying. Yes, i eventually what to do the full timing and tuning of the engine....but for now i just want to eliminate the ping and protect my engine for related damage. I guess i could just keep running premium until i can set aside an afternoon and get my hands on the right tools.
Also, went home at lunch and the engine started pinging with the 89 gas. So when i was there i switched the vacuum line back to the port side of the carb...drove it for a bit and the pinging was real bad, i stopped as switched it back to the full vacuum side and it ran better but still had a ping to it. So im assuming this confirms that i need full vacuum advance?
JG If you can't find it at the junk yard you don't need it. Last edited by Rooster's82; 05-22-2008 at 11:11 PM. |
05-23-2008, 02:16 AM | #22 | |
Re: pinging
But, if it makes the pinging better than on "ported", I would leave it there until you can spend some time on it. |
05-24-2008, 04:44 PM | #23 |
Re: pinging
Can someone break down how timing is kept? Like how the distributer works...the timing mechanism inside of it, how the vacuum advance works, and why you look at the balancer to determine the timing. And any other fundamental aspects of how timing is kept.
