![]() Join Date: Apr 2005
fastburn heads
I have a set of complete new aluminum gm fast burn heads for sale. $700 plus shipping. these are new heads in the box.You can go to any site that sales heads and get the low down on them.edin355
computer illiterate
Re: fastburn heads
whats the part number?
72 2wd blazer 72 swb 4x4 |
Re: fastburn heads
Re: fastburn heads
I believe the P/N is 12464298; if this is the case, then these a screamin' deal on some great heads for a mondo 350 or strong 383/400! "Fast Burn" has been applied to a bunch of different castings, however...
From the GMPP 2008 catalog: When it comes time to own the street, this is the head for you! GM Performance Parts has brought together all of our new technologies to create the ultimate 23˚ small-block GM cylinder head. Fast Burn technology maximizes combustion of the air/ fuel mixture, resulting in higher cylinder pressures and more power production. The combustion chamber (62cc) is designed for flat top pistons, and the head requires no additional porting for optimum performance, so it provides maximum “out-of-the-box” performance. Recommended for any standard coolant flow 1955– 2000 283–400 cubic inch small-block, the Fast Burn head helps us make 425 horsepower from our own ZZ383 crate engine! • CNC-machined aluminum performance head • Completely assembled with 2.00"/1.55" valves • 210cc intake port, roof raised .240" • 78cc D-shaped exhaust ports, raised .200", requires Fel-ProŽ gasket #1470 (may require minor trimming) • 62cc combustion chamber, .400" thick deck (can be milled safely .060") • No heat riser • Angled spark plugs (5/8" hex, 3/4" reach, tapered plugs) • 1.48" Valve spring seat diameter • Use head gaskets with stainless steel fire rings • Raised, machined rocker rails • 0.530" max valve lift (without modifications) • Screw-in studs, (3/8" top, 7/16" bottom) • Dual bolt patterns for perimeter bolt and center-bolt valve covers • Dual bolt patterns for both Vortec and early model intake manifolds • Use production intake gasket P/N 12529094 for Vortec intakes or dual bolt pattern intake gasket P/N 12497760 for either early model or Vortec design manifolds (Fel-ProŽ #1289 and #1207 may be used) |
Re: fastburn heads
Are you willing to ship these to AZ??? I am interested.
Re: fastburn heads
Re: fastburn heads
2nd in line. Shipping to 03036 please.
Re: fastburn heads
Re: fastburn heads
Re: fastburn heads
