Old 05-18-2008, 12:07 AM   #1
troyb_78
10 bolt to 12 bolt
I have an 84 c10 with 3.08 geared open 10 bolt. I am running a new 350 crate motor rebuild 700r4 and 31x10.5 tires. I do most of my driving from 45 to 60 mph with the taller tires I feel like I am really not getting the most of the OD. I would like to go to 3.42 or 3.73 ratio. I have access to a 12bolt out of a late 70 truck with 3.42s in good shape. What I am wanting to know is what is involved in doing a 10 to 12 bolt conversion. I know the u joints are not going to match up and I have heard the 10 bolt drive shaft will be short. Is it worth messing with or should just go looking for a 10 bolt with a higher ratio. Any help of advise will appreciated...
troyb_78 is offline   Reply With Quote
Old 05-18-2008, 01:16 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 10 bolt to 12 bolt
I did the same swap. The driveshaft is okay. All you need is a new U-joint for the axel. The 12 bolts have a smaller cap than 10 bolts. You need a u-joint with two small caps and two large caps.
Clean and paint the 12 bolt before installation.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-18-2008, 01:39 AM   #3
troyb_78
You don't happen to have a part number for that U joint?
Old 05-18-2008, 01:55 AM   #4
troyb_78
Also will the drum brakes off the 10 bolt up to the 12?
Old 05-18-2008, 06:36 AM   #5
SBTork
Garage wrench
SBTork's Avatar
ill second that question. Also, would it be ok to just run the 12 bolt brakes?, because the rear on the newer trucks have that odd brake option, and I think the master cylinder was different too.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-20-2008, 05:38 PM   #6
SBTork
Garage wrench
SBTork's Avatar
.....anyone........
-Adam
Old 05-21-2008, 03:44 AM   #7
74 shortbed 406
I swapped the drivetrain out of an 81 chevy(10 bolt front, 12 bolt rear) into an 87 chevy (10bolts front/rear) and had no problems with the brakes. I rebuilt the brakes on the axles and went
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 05-21-2008, 04:45 AM   #8
1SlowShortwide
1SlowShortwide's Avatar
I used part number Neapco 3-3130 it was about $35.
1SlowShortwide is offline   Reply With Quote
Old 05-21-2008, 05:34 AM   #9
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I did the swap on an 84 K10. I used the brakes off the 10 bolt. You could use either. They will both bolt to either axle and could very likely be the same.
The ujoint is a conversion joint. I know NAPA will have them in stock. I have the number somewhere but I have to find it.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 05-21-2008, 06:04 AM   #10
1SlowShortwide
What was the "weird brake option"?
Old 05-21-2008, 07:06 AM   #11
SBTork
Garage wrench
SBTork's Avatar
well, I know that the later model trucks like mine had two different brake options for the front and rear, I thought they took a different master cylinder but I guess I could be wrong. If it's been done, then it must be ok, but now I know. Thanks for the replies.
-Adam
Old 05-18-2008, 02:29 AM   #12
gchemist
gchemist's Avatar
Sorry I don't have the part number. If memory serves, Spicer 1(?)32 comes to mind. Ask for a 10 and 12 bolt u-joint. Then tell them to find one with the same caps on opposite sides.
