Old 05-19-2008, 01:35 AM   #1
Primered_69
Primered_69's Avatar
How do you get the front cab mount bolts loose?
Got the nut off them but the bolt appears ro be welded on.
Thanks in advance
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 05-19-2008, 01:39 AM   #2
otsenre
otsenre's Avatar
Re: How do you get the front cab mount bolts loose?
It is welded on! leave it there and lift with it on, or if you need it off,grind spot weld off
otsenre is offline   Reply With Quote
Old 05-19-2008, 01:40 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Good luck! I had the same thing happen when I changed mine. It is probably permanently rusted inside the sleeve. I had to cut it off with an angle grinder.
Old 05-19-2008, 01:43 AM   #4
leddzepp
Moderator
leddzepp's Avatar
I was assuming you wanted to change the bolt also. If that is not the case, then do what otsenre said.
