05-19-2008, 01:48 AM | #1 |
Alright Alright Alright
vibrations after new wheel/tire install
yesterday, i took the brand new (1000 miles on them) 275-60-15s and 15x8 wheels and tires off of my perfectly riding 78 sport van and put them on my 72 cheyenne. it rides fine in town, but when i get on the highway, it will have a slight vibration (i can see things bouncing in the cab). what could cause this? i thought it would be a direct swap. how can this be when it rode perfectly on my van?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
05-19-2008, 02:19 AM | #2 |
its all about the +6 inches
Re: vibrations after new wheel/tire install
Is there a chance you didn't tighten the lugnits?
Or maybe a chance that the lug nuts are closed on the end and couldn't spin all the way on? |
05-19-2008, 09:16 PM | #3 |
ill give it a closer look and get back to you.
05-19-2008, 09:28 PM | #4 |
Where spicificaly is the vibration at.?
05-20-2008, 08:13 AM | #5 |
im not sure where is occurs. today, i took the center cap off and saw that the center hub of the rotor had a 16th of an inch of gap all around it between the wheel. the rally wheel fit perfectly flush. i have switched them out and no more vibration. these wheels were ordered for a 78 chevy truck. how is it not compatable. it was also the same on the van too.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies Last edited by crm318; 05-20-2008 at 08:15 AM. |
05-20-2008, 02:53 PM | #6 |
I would wonder if your tires are wearing differently than they did on your van. Maybe your alignment is just a little bit different. Another questions for you is are the tires rotating in the same direction that they were before? Sometimes that makes a difference.
05-20-2008, 11:56 PM | #7 |
they were put on the same way.
05-21-2008, 05:35 AM | #8 |
05-21-2008, 07:42 AM | #9 |
i would think that the lugs would keep the wheel centered, but the center should also take up a good share of the load. its a shame.......and annoying to swap them back.
05-21-2008, 12:15 AM | #10 |
It could be a slight tire weight difference and your drivetrain, because it sounds speed dependant, maybe the tires/wheels are causing another issue to be more prevelant?
05-21-2008, 04:57 AM | #11 |
My .02
I would recommend you look at your suspension mounts, and also consider your shock(s) and or springs. It may be that your tire is slightly out of balance/round and was compensated on your other car. You could have a worn shock, loose mount somewhere, which is all worsened or magnified by a out of round or out of balance (slightly) tire. If you have something that is slightly out of balance or round such as a tire, spin it at high speed, you can create a pretty sizeable vibration. Is this happening with only one tire, two tires, or all of them? I am by no means a suspension guru, just done a lot of work with vibration.
My other vehicle is unmanned.... |
05-21-2008, 04:55 AM | #12 |
gotta figure why the wheel isn't going on all the way.
