Transmission WOES! GuRu's needed!
I just picked up this truck and got it running, now when i start it trans fluid starts pumping out. I had the trans pulled out and replaced the gaskets, and now it's still doing it, what gives? Any help or insight is much abliged.
Moderator
![]() Join Date: May 2007
Re: Transmission WOES! GuRu's needed!
Where is the fluid coming out of? Did you check your cooler lines going to the radiator?
Gettin By on Gettin By
agree.. where is it leaking?? what kinda trany??
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" Last edited by jayharrell; 05-20-2008 at 01:41 AM. |
![]() Join Date: Dec 2006
You have a crack in the case exactly 1 13/32 " above the governor housing.
No seriously,tell us more and we'll try to help.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
In my case after having the 350 rebuilt with a new converter it let loose lots of fluid. After close inspection it was coming out a small hole I believe on the side. Discovered it must be a weep type hole. As I discovered I had over filled by almost a quart. Since no more problems.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
I believe its a Th350, the cooler lines are all good. The fluid is coming from the bellhousing area. It's not just a lil fluid, it's like it's being pumped out, when it's overfilled would it do that?
its all about the +6 inches
overfilled, or filled improperly... either could do this.
Crawl under, and reach to the top of the tranny. You are looking for a metal tube... a small pipe... see if the fluid was spraying from there. Last edited by Longhorn Man; 05-20-2008 at 06:18 AM. |
It would have to be DRASTICALLY over filled to puke. I'm gonna guess you have either a cut , or wrong front seal, or crack in converter neck.
if there is a crack in the neck will i be able to see it with the trans out? and would i just have to put a new converter in?
Clean the neck, and dry it. then fill the converter FULL, let it set for 10-15 minutes. if it gets wet you have a leak.
I would bet it is overfilled. Firedogs 350 done the same thing as mine & his didn't quit but on occasion for a week. Even though it appeared to be done for a few days then another cup on the floor. Needs to get the air out of the system.
So are you sayin just let it run and pump the excess out? Then check it occasionally? I just don't want to burn up the pump or anything.
