LIKE 'EM BIG AND TOPLESS
May have the chance to pick up a rear Dana 60 out of a '71-'72 with 4.10 ratio..whats the pros and cons and are any mods needed to swap into the '70k5? Thanks for the help...
wrath ------------------ LIKE 'EM BIG AND TOPLESS !! <A HREF="http://communities.msn.com/OurMudToys I" TARGET=_blank>http://communities.msn.com/OurMudToys </A> Check out my '70K5Blazer 350/205 (project 35"BOGGERS)4"suspension/3"body installed,starting bodywork&paint 86K5BLAZER 454ci.350/205 case 4" susp.,3"body 3/4ton4.10s 38"Swamper sx 83CJ-7 304ci.edelbrock 600 and performer intake ,headers 31"Swamper sx '86 GMC plowtruck (BOSS V-PLOW) "Welcome to where time stands still No one leaves and no one will Moon is full,never seems to change Just labeled MENTALLY DERANGED..." "THE INTIMIDATOR" gone but never forgotten !!! |
Is the Dana out of a 3/4 ton or half ton.?
------------------ Orlando,FL 72 Chevy 4x4 3/4T CustomCamper w/SB 406
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
3/4..I believe..havent had the chance to go look at it yet ..just heard about it couple hours ago..didnt know they made a Dana 60 for 1/2 tons..
Suburbans RULE!
There were 6 lug Dana 60's available in '67 for the 1/2 tons. If the Dana 60 you are looking at is from a 4X4 then it will bolt on to your K5 if it is a 4X4. The 2wd's had a different frame width than the 4X4's. If it is a coil spring rear than you will have to change brackets and mounting pads all together. To check which what it came out of, measure the center to center of the leaf spring pads. 4X4's measure 40" and 2wd's measure 42.5" The shock mount tabs are different as well if it is a 2wd.
Of course once you determine that you will need 8 lug rims and possibly a hybrid u-joint. I am in the process of putting a Dana 60 out of a 67 GMC C20 into my 71 GMC K10. ------------------ 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
its all about the +6 inches
Well, the leaf springs on a one ton or any longhorn has the same pad width as a 4X4 does.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
Suburbans RULE!
How may guys have Dana 60's in their one tons or longhorns? I don't think the Dana 60 was used in one tons......someone correct me if I'm wrong.
I know they were in 3/4 ton Longhorns, not sure bout one tons though...both my old one and the current one have Corprates. LonghornJeff has a dana in his 69 3/4 ton.
most all dana are int he 67-72 3/4 ton, lots of them around, even here and thats sayting soemthing, i know of two right now i oculd go straight to, one laying by the street over on north kickapoo and one under a truck a few blocks from there truck for sale 300, but rusted junk,.
67 shows no availability of 1/2 ton dana 60, but 69 model year does, but only with 435CR tranny with the 396. odds of finding that are verrrryyyyyyyyyyy slim. odds of finding a 1/2 ton verion with 40" centers is slim also, but very common 3/4 ton 40" center like your blazer is. good luck ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase, #1 -90 Cavalier 2.2L sky blue, a driver -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2 -82 purple Trans Am, project #3 *Paint is overrated* © RSS Enterprises 2000 |
Suburbans RULE!
My info on the '67 6 lug Dana 60's came from GMC Paul. That was my point that a Dana 60 from a 1 ton or a longhorn would be pretty scarce....possible but scarce. He most likely has one from a regular C20 or K20.
