05-25-2008, 08:30 PM | #1 |
Always wrenching!!
Helper bags???
I want to keep the coil springs but i need a helper bag when i pull trailers. Whats every one running?? I know theres bags that go inside the coil spring. also can you run a seperate bag infront of the spring on the trailing arm?? any help would be great.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
05-25-2008, 10:14 PM | #2 |
Re: Helper bags???
I use Air-Lift air springs from Jeg's.Part #022-60844.They are about $78 and I've used these for several years.In my opinion,they work great.I run a 70-72Monte Carlo rear spring for a nice ride,but you can air them up and haul a ton because they limit the travel of the coils.Cheap and effective,and if you race,they work good for that also.Good luck.
05-25-2008, 11:54 PM | #3 |
Always wrenching!!
Re: Helper bags???
are the monte carlo springs the same diameter as the truck spring?? or would i need to find a differnt bag??
05-26-2008, 07:28 PM | #4 |
Re: Helper bags???
I believe they are the same diameter,and they bolt in the same way as ours.I drilled a hole through the frame for the air fitting so it wouldnt kink or break.I believe these will also work with the truck springs with no problem,but it will be a firmer ride,from the stiffer springs.These things are great for the money.Also you can fill them together or set it up to fill each individually.
