06-02-2008, 07:36 PM | #1 |
My Project just took ANOTHER turn,
Ok so just when i thought i had my frame just about ready to be a rolling chasis again i got bit by a different bug and my project is taking another turn.. I work for a salvage yard and a 94 buick Roadmaster with 77,000 original miles little old man driven came in wrecked light in the front. i picked up the LT1 and the 4l60E for just over a grand for everything, compresor, starter, alternator, computer, wiring, ps pump. and air box.... ive done plenty of reading about these swaps and decided for that kind of money i think it would pay for itself in gas mileage after to long. from what ive gathered heres what i know... add to this if theres something im missing:
1) will have to notch the frame for the air compressor to fit properly. 2) the motor mounts and tranny mounts are the same however i will need to shorten the drive shaft. 3) the transmission requires a conversion for the electrical speedo to be cable driven, *several websites ive seen on the board advertise them* 4) will have to eliminate quite a bit of wiring, from what ive seen theres books out there to help with this, or custom harnesses are avaiable, 5) will need to address the fuel situation *return line* stronger electric pump etc, Thats what ive gathered so far. what am i missing guys? do you guys think i got a good deal for the money. this set up looks VERY clean, no oil leaks and no dirt or anything on the motor. still has all the factory heat shielding insulation wrap on all the wires and looks almost brand new and runs like a champ. according to the oem specs the 94 roadmaster iron headed 350 lt1 motors put out 260 horse and 330 ft. lbs of torque, sound about right on those numbers? thanks for your imput! -Andrew |
06-02-2008, 08:03 PM | #2 |
Well, Whoop-dee-do!
Re: My Project just took ANOTHER turn,
Sounds like a pretty good deal to me! Never been around the swap myself, but I would think if YOU get to pull it & can pick off every donor trinket you can snag... it shouldn't be too tuff. I'm curious how an electric speedo pickup sensor can spin a cable though.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
06-02-2008, 08:31 PM | #3 | ||
Bloo
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
06-02-2008, 08:55 PM | #4 |
doing some more research on it it looks like what is mostly advertised out there converts the rear tailshaft back to a mechanical speedo with also the eletrical pulse still there to go to the computer and they run around 300 to 400 bucks. but idk is there something out there someone can do?
06-02-2008, 09:53 PM | #5 | |
Bloo
according to the trans guy i work with, had i thought about the electric speedo before i put the trans in, he could have put a manual gear in it... other than that or the $320 converter i found though, i have no clue how to do it. mine is set up to where a normal speedo driven gear can bolt in where the speed sensor bolts in
06-02-2008, 11:34 PM | #6 | |
06-03-2008, 12:49 AM | #7 | ||
Bloo
what you need is this: http://www.bowtieoverdrives.com/hot/ scroll down to the cable X you could then splice the cable-X into you VSS wires between your trans and ECM, and hook a cable up to your speedometer... pricey lil booger though edit: found another site: http://www.abbott-tach.com/cablex.htm
06-03-2008, 07:55 AM | #8 |
thanks for the info, the kit from bowtie overdrives is what ill probably go with. only a couple hundred bucks to get it set up and working correctly, thanks guys is there anything else anyone can think of i may run into thats kind of tricky on a swap like this? maybe someone who's already done this swap can chime in, ill probably be using an aftermarket electric fuel pump, ive got a blazer fuel tank mounted on the frame already any suggestions there?
06-02-2008, 11:38 PM | #9 |
For your tranny gear speedo issues check out jagsthatrun.com. I bought a converter that I ran off my 205 transfer case that would feed the VSS signal to my computer. I don't think that's exactly what you are looking for, but they may have what you need.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-03-2008, 11:02 PM | #10 |
Why does the frame need to be notched for the a/c, could you use a diff. compressor?
06-03-2008, 11:47 PM | #11 |
I probably could, although im not sure which one??? and plus i bought this whole set up with all accesories, so i might just make the notch to allow for the compressor i got. its not a big deal from what ive seen,
06-05-2008, 05:14 PM | #12 |
Yup, I'm comp-useless
You may want to check into the accessory drive from a 'vette. I know the a/c compressor is placed different, and believe that I have read something about this swap not needing the frame notched. You may just need the 'vette accessory mount.
1972 Chev Suburban(ongoing driveable project) 2010 Harley Wide Glide 1996 Subaru Outback(daily beater) !992 T-Bird Super Coupe(yet, another project) 1995 GMC Suburban(will be for sale, soon) 1995 Dodge 3500 Club Cab(Cummins 12V) 2001 Freightliner(Cummins Powered Money Maker) |
06-05-2008, 09:21 PM | #13 |
has anyone used www.speartech.com for wiring their project. they seem to have a good looking product, a bit pricey for a new LT1 harness (650) but i imagine if it saved me the headache of wiring it'd be worth it..
06-03-2008, 11:54 PM | #14 |
good luck sounds like a winner to me!!
06-04-2008, 08:34 AM | #15 |
Tot Roddin'
nice sounds like a nice buy andrewt2!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-04-2008, 01:53 PM | #16 |
Thanks guys, gonna get it home tonight i think, the motor and tranny are both EXTREMELY clean, im thinking ill be bring it home from work tonight and ill post pictures, if i can get some LT1 guys to chime in here... what did you do about your power steering set ups... on this motor the ps pump is on the passenger side and the lines run clean over to the box, did you have them make you some lines with metric fittings for the pump and sae fittings for the box itself? just wondering! thanks guys,
06-04-2008, 06:36 PM | #17 |
Freeeeee Mason...
For that much hassle, I would have found an LS1 instead.
Daily Driver -2007 Chevy -Dark Blue Metallic -Regular Cab -4.8 V8 -4x4 Ongoing, Never Ending, PITA, Love of my Life -69 Chevy C/10, Camper Special -350/TH400 -Loudest System on the Board |
06-04-2008, 07:10 PM | #18 |
street and performance aka hotrodlane.cc is a good source of all the swaps for classic trucks. they make mounts and also have an install page of prior conversions they performed.
Sledge |
06-04-2008, 11:55 PM | #19 |
06-05-2008, 12:03 AM | #20 |
heres a few pictures of the motor and tranny, like i said i got everything, accesories, wiring, computer, tranny and all for just over a grand, 72k tranny looks clean enough to eat off of.
06-05-2008, 03:42 PM | #21 |
give these guys a call they will send you a catalog and how-to dvds for your swap they specilize in lt and ls swaps.
Street & Performance, Inc. ph: 479-394-5711 web : www.hotrodlane.cc doing a LS/460LE swap on my 70 myself and they where best price for the wiring harness which is wired for the tranny too. most places i found only build the wiring harness for the motor and expect you to hook up a th350 or th400. anyways check em out they are really helpfull and have everything you need to do the swap. Last edited by winson; 06-05-2008 at 03:44 PM. |
