06-03-2008, 01:10 PM | #1 |
Check out his home-made power steering swap job
I meant THIS home-made job...
When I bought the truck I noticed - even just pushing it around - how the steering felt kind of funky. Started tearing into it and found this beauty: The hole behind it: Starting the repair: Finished - with the CPP kit: Not having the original holes to use as guides that the CPP kit calls for made it interesting.. Last edited by Lane; 06-03-2008 at 08:18 PM. |
06-03-2008, 01:59 PM | #2 |
Re: Check out his home-made power steering swap job
That's incredible...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
06-03-2008, 02:15 PM | #3 |
WOW!
what a mess, your fixed her up right nice though, kudos!!
CHEVY ONLY |
06-03-2008, 02:30 PM | #4 |
Ol' Blue Viking
One of mine used old lugnuts to space it off.
Scary!
Driving Paw-paws truck into the Sunset! |
06-03-2008, 02:50 PM | #5 |
Yeah - there were some lugnuts in this deal too...
06-03-2008, 02:39 PM | #6 |
The funny thing is, he had the right idea. The frame is not strong enough to support the torque of the PS gear and so he 'gussetted' it.
Unfortunately, after he did that, what little was left of the frame was probably weaker than it was originally. Nice job on your repair though |
06-03-2008, 03:35 PM | #7 |
I just saw a frame that had no spacers, they just tightened the front bolts first then the back so the gear box was cock-eyed. people do some crazy chit
CHEVY ONLY |
06-03-2008, 03:59 PM | #8 |
Thanks for sharing, that was one major bodge up
Cool repair. Steve. |
06-03-2008, 05:45 PM | #9 | |
One day...
Nice work on the fix, Lane |
06-03-2008, 04:08 PM | #10 |
Lane, what are you supporting with the bricks? They make horrible jack stands... I used to use concrete blocks and about got crushed doing it...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 06-03-2008 at 04:09 PM. |
06-03-2008, 05:16 PM | #11 |
I was using them when I was test-fitting the I6 before I got the 5.3 that's in it now. Can't remember why I was using bricks for that purpose though.. lol
06-03-2008, 04:30 PM | #12 |
Cantankerous Geezer
He didn't try welding the box on the frame?
Seriously, let me ask some questions about what you have done. I think I am seeing an unwelded crack in your repair. If so, take off the new box and fix it now. Drill a hole at the very end of the crack, then bevel the edges and weld on both sides. Also, are the plates under the box sitting flat against the frame? If not, grind the welds while you have things apart. I would also recommend either welding the plates to the frame or locally boxing the frame. If you box, leave things open enough to unbolt the steering gear. I would also give a lot of thought toward sending the frame out for straightening before mounting any sheet metal.
Fred There is no such thing as too much cam...just not enough engine. |
06-03-2008, 08:40 PM | #13 | |
I've measured the frame front and back and it is pretty square - for such an old truck. All my measurements were within a 1/4" or so, and only in a couple of places was that far off. Not sure what the factory tolerances were, but I bet it's close. I may have it looked at anyway, just to be sure. Thanks for the comments. |
06-03-2008, 04:39 PM | #14 |
with this kit, does the box only mount with 3 bolts?
CHEVY ONLY |
06-03-2008, 06:38 PM | #15 |
No - it has four, but one goes in from a different side.
06-03-2008, 07:12 PM | #16 |
i see 4 bolts, but only 3 go to the box, and the 4th is only bolted to the bracket, what about the 4th box hole???
CHEVY ONLY |
06-03-2008, 08:46 PM | #17 |
The 4th box hole is bolted/threaded to the outer plate - and hangs below the frame rail just a little. Had to go out to the garage and look at it again.. lol It's been a few months...
06-03-2008, 10:08 PM | #18 |
Rust Buster
Hey I've seen that work before is that from Bob Chopenhack's shop?? Jerry
06-04-2008, 01:05 AM | #19 | |
thanks
CHEVY ONLY |
06-03-2008, 08:20 PM | #20 |
454 club
Wow what a mess that was. Nice job fixing it.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
06-03-2008, 08:32 PM | #21 |
Nice job Lane. I had to do something similar on my 77, but at least there was no P.O. to mess things up! I welded a heavy backing plate behind the original side rail, because these trucks (73-87) are known for cracking at this location.
But, like Fred said, if that one seam isn't welded, fix it now.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
06-04-2008, 10:47 AM | #22 |
Good idea - too.
Glad I posted this.. I think.. lol |
06-04-2008, 09:29 PM | #23 |
1 thing at a time is progress.
I'm glad I read this post. I knew about the spacers, but didn't consider boxing. Ya'll saved me cause I hope to be painting my frame this summer.
Alan
Philippians 2:14-16 |
