Old 11-08-2002, 01:00 AM   #1
crazy longhorn
Fabricate till you "puke"
Low 69 CST
I checked the pics on your blazer tank, & it looks to fit pretty nicely. I have been thinking about that poly tank for the longhorn, & was wondering how far below the rails it hangs?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-10-2002, 08:52 PM   #2
Low69CST
Hey, sorry it took me forever to respond. It fits nicely now, but was a serious pain in the butt to put in. I'm thinking the tank hangs maybe 5 inches down past the bottom of the frame rail. I think i'm going home wednesday, so I will check it then and be sure to get back with you. But I know on my truck, the tank is not visable at all.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-10-2002, 10:02 PM   #3
crazy longhorn
Hey, thanks for the reply. I dont really need an exact measure, if its 5-6" below the rails it wont cause any ground clearance problems & Im sure it wont show on my old lowrider I have looked at the fuel cells, but 16 gal is about all I can fit....... the last crossmember is quite a ways from the end of the frame & that wont go far @ 8mpg! The blazer tank looks like a nice way to go.....
