11-08-2002, 01:12 AM | #1 |
P.S. pump pully?
Has anyone ever removed the pressed on power steering pump pully? How do you do this? Mine is from an 87 truck with a serpintine pully and I need to put on a V-belt pully. I would like some input before I start putting it on the press. Is the allen head on the end of the shaft something that needs to come off first? Thanks.
68 LWB, .040 over 350 with 10:1 pistons, balanced, vortec heads,comp 270H cam, air gap RPM manifold, holley 750, 4.10 posi and gear drive to annoy the neighbors. |
11-08-2002, 11:29 AM | #2 |
You need a PS pump pulley remover. You can get one from Harbor Freight for between $10 and $20 depending on what they have in stock or on sale.
11-08-2002, 05:27 PM | #3 |
Hootis is as Hootis does...
My local Carquest autoparts store had the tool. I just brought in the pump and we yanked the old one off and put the new one on. I forced a $fiver on him as a tip - they were real nice about it.
Good Luck. |
11-09-2002, 01:05 AM | #4 |
Thanks for the replies. I'll be trying it this weekend. Hope it works, if not, oh well. A trip to pick&pull is always fun.
11-13-2002, 08:00 AM | #5 |
Just an update. I got a remover/installer kit from Harbor Frieght for $10. It worked great. Easy to remove when I have the right tool. Thanks again for the info.
