calling all garage mechanic's
as alot of you know through past contact, I am new to this classic truck arena. was curious if any of the oldies would be interested in throwing some info out there like what-fits-what?
we have only owned our vehicle a short time and have put together a wish list for this coming winter. first and foremost would like to upgrade to a newer style frame with IFS, power steering and brakes. been doing lots of research the past month, newer full size truck frames, S-10 frames, Camaro and other such sub-frames. definately not afraid of some work, let the options fly and will keep everyone informed and updated as project proceeds w/photos. Last edited by rockdogg; 06-10-2008 at 07:44 PM. |
Re: calling all garage mechanic's
i went with a nova clip on my 57, had it cut and tacked, in about 3 hours
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
looks pretty straight forward and nice.
does anyone know if a mid-60's Cutlass frame would fit under a '56 PU? and how much work would there be to re-locate body mounts. Last edited by rockdogg; 06-10-2008 at 10:29 PM. |
It could probably be made to work, but I would use one that already has disc brakes, it would save time and money.
My 57 has a 67 chevelle front clip on it. This is the best pic I have of it right now. If done properly it is a very clean install.
Kim |
as of current replies, it seems that most go for the cut-n-patch front-end.
the main reason I asked about the Cutlass is that there is one available near me that was an original "442" and is a rolling chassis w/10 bolt posi-rearend. which I'm sure you all realize that would be a pretty good upgrade if doable. and yes, disc brakes at least up front. this would be IFS, power disc brakes and steering. with a 10 bolt posi-rearend. |
#7 | |
1964 to 1972 were considered "A" bodies which is what the chevelle is so it should be the same as the clip on my 57. There are a ton of upgrades you can do to it to improve on what they came from the factory with. Kim |
it's actually a '67, I'm currently looking into the cut and patch front-end and just adapting the rear-end to fit the stock frame. should be relatively close in axle width.
