Old 06-14-2008, 03:48 PM   #1
71GMCEWAN
71GMCEWAN's Avatar
Question Wheel hop
I just replaced my 308 posi with a set of 411's, and now have a bad case of wheel hop. My truck is a long box with leaf springs. Does any one know how to STOP the HOP
71 GMC LWB GMPP Fast Burn 385 crate engine, T-350, Factory A/C, tilt, gauges, buckets and console changed to houndstooth bench, 411 posi.
Click Here for pictures
71GMCEWAN is offline   Reply With Quote
Old 06-14-2008, 05:01 PM   #2
whatnow123
whatnow123's Avatar
Re: Wheel hop
Sounds like you need some traction bars... availble just about anywhere but I'd check Ebay first.
BTW, it's becuase your leaf springs are "wrapping up" when you get on it. Coil spring trucks don't have this problem.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 06-14-2008, 05:34 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Wheel hop
An old school method was to install a set of Air Lift air springs....drag racers would preload them, to offset the side that would hop. The old ads showed them burning rubber with both tires with nothing more than the Air Lifts installed.
Member Nr. 2770
Old 06-14-2008, 11:40 PM   #4
IAFF2407
IAFF2407's Avatar
Re: Wheel hop
I had the same problem, believe it or not, when I put my Gaylord's tonneau cover on (100 lbs.) it completely stopped.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 06-15-2008, 01:57 AM   #5
bucky_21_7
bucky_21_7's Avatar
Re: Wheel hop
i got it also blew up 1 yoke and 2 ddrive shafts. i'm geting tration bars built that wil lride on the frame and i'm gonna lock up the front springs
bucky_21_7 is offline   Reply With Quote
Old 06-15-2008, 03:37 AM   #6
1969-08 chevy
1969-08 chevy's Avatar
Re: Wheel hop
If both of your shocks are mounted in front of the rear end, then you can remove one from the front and place it behind the rear end. You will have to make new brackets. Alot of people do it to 4x4's so you don't get wheel hop on rough roads. Your case probably needs traction bars, but every little bit helps.
1969-08 chevy is offline   Reply With Quote
Old 06-15-2008, 09:39 AM   #7
71GMCEWAN
71GMCEWAN's Avatar
Re: Wheel hop
Thanks guys, I was hoping for something a little more discreet than old school traction bars.
I have a soft tonneau right now. I will look at the shock set up today.
Has anyone heard of a "hotchkis setup"?
