06-14-2008, 11:05 PM | #1 |
How many miles before a suspension rebuild?
My c10 has 94000 miles. Front and rear suspension all original. Upper control arms still have riveted balljoints. Truck starting to feel a little loose but still handles better than my car with a skinies on it. Lower balljoints have play in them. How many miles before a suspension rebuild on these old trucks?
06-15-2008, 09:59 AM | #2 |
Re: How many miles before a suspension rebuild?
I'd say it depends on the owners maintenance habits. 94K is a lot of miles,so just check everything.If it's out of spec,replace. My truck has 170K and all it's had is one ball joint,but I need to check it again soon.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
06-15-2008, 10:02 AM | #3 |
Do it now...any movement of the ball joints indicates wear. If you wait and one goes out on the freeway it won't be good for the truck or you.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-15-2008, 10:31 AM | #4 |
Yeah, ^^^ if it is loose enough that you know it, it's time to replace.
06-15-2008, 10:57 AM | #5 |
Chevy nut
I say the same thing...loose replace.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
06-15-2008, 12:30 PM | #6 |
I will replace it. I would rather pull and redo motor, trans or rear. I never liked suspension work.
06-15-2008, 02:07 PM | #7 |
Chevy nut
Its easy. A grinder to take off the heads of the ball joint rivets...ball joint pickle fork. Take the nut off...no problem.
06-15-2008, 04:12 PM | #8 |
IMO, if you can tell there is wear, it's past time to do it...
I don't know how many miles my 'burb had on it when I did it's suspension, but it needed replaced long before I bought it!
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
