Old 06-15-2008, 03:32 AM   #1
original_balzer
original_balzer's Avatar
my is frame painted with rattle can question
The previous owner painted the frame with rattle cans. After he had it sand blasted. My question is do I need to take it back down to bare metal or just scuff it up real well?
I know that rattle can paint is not as good as real paint. So is it going to cause a problem being under a product like por 15 and chassis black?
The PO said he put 2-3 coats of primer then there is 1 coat of stupid silver on the top.
Rustoleum is the brand he said he used.
original_balzer is offline   Reply With Quote
Old 06-15-2008, 06:36 AM   #2
don t. - 72gmc
Re: my is frame painted with rattle can question
IIRC, and its been about 5 yrs now, POR15 needs bare or sand blasted metal to adhere properly. The running boards of my 2N ford tractor, all I did was a wire wheel on a drill the heavy rust off. Its holding up ok but it aint no trailer queen.
HTH....have fun.....don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 06-15-2008, 11:14 AM   #3
caminokid
Chevy nut
caminokid's Avatar
My 69 stepper has been done the same way. I know I have to strip it down and start all over again. Thats the only POR-15 is going to stick.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-15-2008, 04:10 PM   #4
original_balzer
Thats what I was afraid of consitering I dont have aceass to a sandblaster.
So whats everyones oppinion on paint stripers such as the aircraft stuff? Would that be good enough to take it down to bare metal?
Perhaps I should just get all my frame mods done and send it off to be sandblasted and powdercoated.........
Old 06-15-2008, 04:29 PM   #5
HoupPhotography
That's the best idea! If your doing mods to the frame, why would you paint it now?
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 06-15-2008, 04:48 PM   #6
original_balzer
IM not panting it now. I just thought about the rattle can paint the other day and realized Id probably have to strip it back to bare metal. It would suck to get everything done then a year from finished the rattle can paint start releasing on me. Call it foresight if you will. I doubt Ill get it powder coated though. Thats probably out of my budget.
Old 06-15-2008, 07:46 PM   #7
jorgensensc
jorgensensc's Avatar
I have to voice another opinion. I have used POR 15 several times on many frames. It does not stick worth a darn to a nice clean frame. If you sandblast the frame, I would go ahead and let it flash rust. POR 15 is designed to be used over rust. If it were my frame, I would sand down the whole frame (using like 50 - 80 grit), not all the paint away, just really rough and then let it sit outside, or spray some water on it and let it sit for a few days. Then POR 15 the frame. If you put it on a smooth fame it will peel right off.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-16-2008, 03:00 AM   #8
leddzepp
Moderator
leddzepp's Avatar
Shawn
I agree.
Old 06-15-2008, 07:50 PM   #9
Sammy
You should rough it up & use a good etching primer.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-15-2008, 08:27 PM   #10
cdowns
cdowns's Avatar
most rattle can paint will wash right off with laquer thinners no need to blast
Old 06-16-2008, 03:02 AM   #11
leddzepp
Moderator
leddzepp's Avatar
Put some chemical stripper on it, wash it off, let it flash rust a little, then POR 15.....done.
Old 06-16-2008, 05:22 AM   #12
original_balzer
SWEET
