Old 11-08-2002, 03:41 PM   #1
69see20
Finding top dead center
I just rebuilt the top end of my 307. I have the heads intake and timing chain cover all back on. I am ready to set the valve lash and set in the distributor, but am curious how to set top dead center with the dizzy out. does anyone tell me how to find top dead center like this? I know to look for the timing mark on the balancer, but do not know if it is on the compression stroke or exhaust stroke.
69see20 is offline   Reply With Quote
Old 11-08-2002, 03:50 PM   #2
lux hauler
Psycho-billy Member
lux hauler's Avatar
with the #1 spark plug removed, put your finger over the spark plug hole and turn the motor over. when air starts pushing out of the hole, the piston is coming up on the compression stroke. bring the piston to the top.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 11-08-2002, 08:59 PM   #3
72K10
Another way that has worked well for me is to wet a 1/4 chunk of paper towel and stick it in the # 1 cylinder hole ( plug pulled). Bump the engine until you hear the paper towel blow out - sort of a "pshhhhhht" sound. If you have your harmonic balancer installed, turn over by hand until line on balancer aligns with tab. Then your at / very close to TDC.
Chris
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 11-09-2002, 12:16 AM   #4
Capitol68
Capitol68's Avatar
Yea what 72 said is the easiest if u are by ur self. or use a shop rag
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 11-09-2002, 12:47 AM   #5
crazy longhorn
Fabricate till you "puke"
If you still have the valve covers off, you can set the timing mark to zero.......if both valves on #1 are shut, you are in the right spot. If not, turn the eng 1 revolution back to zero.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-09-2002, 01:59 AM   #6
COBALT
COBALT's Avatar
I once did the "blow out the hole" trick, but found that it was easier to rotate the engine with all the plugs out and stick my pinky in the spark plug hole until I could feel the top of the piston. For some reason I had a hard time getting TDC with just bumping the starter...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
