06-16-2008, 03:44 PM | #1 |
In Box spare tire mount
Does anyone have a picture of what the rod/bolt looks like that is used to mount the spare tire inside the bed on the factory mount?
I am talking about the mount on the inside of the bed in the left front corner. I have the mount inside the bed, but no bolt or rod. Anybody have any suggestions for what they have used to mount a tire here?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
06-16-2008, 04:27 PM | #2 |
Re: In Box spare tire mount
I have another thread on here asking about the same thing. I would like to see the original setup also, but it appears that pics of that setup are hard to come by.
TTT
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
06-16-2008, 04:58 PM | #3 |
I have the same setup in my longbed. what I did was I got a mounting hook and butterfly nut from a trunk mounted spare in a 80`s gm full size (like a monte or regal) and the cap that mounts in the hole for the hub of the rim. I had to lengthen the J hook (mounting hook with threads fot the nut) with a piece of all thread and there you have it. Sorry no pics but you can find those mount hooks and butterfly nuts in any salvage yard. the J hook fits perfect in the mounting bar attatched to the inside of the bed
1967custom |
06-16-2008, 07:38 PM | #4 |
Thanks Michael, several of us are looking for photos of how they looked when they rolled out of the factory. I currently have mine set up in a similar way as yours but I want it to be the way it was originally.
Jeff
06-16-2008, 10:15 PM | #5 |
does this help
from my '72 GMC....original as best I can tell by paint spray (for bolt and round plate) as for wing nut don't think so...but??
'70 Pontiac Firebird Esprit '72 GMC 2500 '90 GMC V1500 '94 Dodge Cummins 2500 '02 Dodge 2500 Quad Cab Long Box 4x4 gasser |
06-16-2008, 10:55 PM | #6 |
Could be correct, I don't know
This is Jayshays pic from the other post, I am puzzled by the bolt that is circled. All of these brackets have a slot for a bolt that goes up and down, surely something went there and it did something?
06-17-2008, 02:52 PM | #7 | |
A slot in the bracket really does not make it of much use on mine for holding anything other than possibly pinching the bolt there to be out of the way should you want the full bed other than that I think mine is original as it came with the original spare with the wing nut being the only thing I figure is not (is a nylon locker nut with a bracket attached) all I can figure
06-17-2008, 03:50 PM | #8 |
Here's what I use. You can order them from J.C. Whitney, I think.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
