06-18-2008, 04:09 AM | #1 |
drive it till it dies
door hinges??
what is an easy way if any to fix sagging doors. my drivers side door rubs on the bottom of the door jam when i close it. its already rubbed some of the paint off.
live life to the fullest |
06-18-2008, 04:25 AM | #2 |
Re: door hinges??
If you open the door and gently move it up and down you can see if the play is in the hinge and pin itself or if you just need to re-adjust your doors through the hinge bolts. I have had my doors on and off quite a bit, and they are a pain to get lined up rite.
06-18-2008, 06:59 AM | #3 |
Old Skool Club
Re: door hinges??
I am going to hazard a guess that it is the hinge pins that should be replaced, not the hinges. At least, they're cheaper and may be all you need to do. If not, you'll know what to do.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-18-2008, 07:21 AM | #4 |
Re: door hinges??
Advance Auto & Auto Zone & others, have door hinge kits for around $10. Also, you can get the hinge bushings from GM dealers.
1997 GMC Sierra Ext 1965 Mustang |
06-18-2008, 07:51 AM | #5 |
67-72 Addict!
Re: door hinges??
I didn't realize I could get these locally at the parts stores. I thought I had to go to the dealer.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
06-18-2008, 08:01 AM | #6 |
Prestige Worldwide
Re: door hinges??
06-18-2008, 07:09 PM | #7 |
Re: door hinges??
If there's a red help section the P/N is 38400. You'll need 4. For example:
http://www.rockauto.com/catalog/rafr...0&a=FR42-38400 BTW: The old pins can be pretty easy, or really hard to get out. Last edited by 72lb4x4; 06-18-2008 at 07:13 PM. |
