View Poll Results: which carb should i get for my 462 BB
edelbrock 850 qjet 14 56.00%
holly dual feed double pumper 10 40.00%
stop asking for advice so i can learn from my mistakes 1 4.00%
Voters: 25. You may not vote on this poll
Old 11-08-2002, 09:39 PM   #1
>X<
registered IWATA user
>X<'s Avatar
Poll: double pumper or qjet?
aaaarggggghhh!!!! everyone i ask that knows what there talking about says something different! 462 with 292 cam, dont care about gas mileage. i was so close to ordering a 850 qjet, then at work i was talkin gto a guy that builds the diesels for the trackmobiles that we build and he has built a couple 11 secind cars, his current an elcamino, and he says get a dual feeddouble pumper 850, volume is best for my motor??
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 11-08-2002, 09:49 PM   #2
crazy longhorn
Fabricate till you "puke"
For your combo, Id go with the Holley dp......I would think 800 cfm would be enough, unless you plan a strip only deal. good luck
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-08-2002, 10:25 PM   #3
mooneyes
mooneyes's Avatar
i agree with crazy longhorn..if performance is what u want go with the d.p.
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 11-08-2002, 11:40 PM   #4
>X<
>X<'s Avatar
thanks guys, i want the most possible hp so i'm gonna go with the 850. i dont know where i got "dual feed" from, what is the diff? is a double pumper a dual feed? so i should order the "classic double pumper, 850 CFM classic carb, 429.95"
one more question, which intake manifold do i get to go with this, i am going with the performer rpm, but do i get the spreadbore or oval port? is the dp a spreadbore? whats ths diff between the spreadbore intake and the oval? thanks, sean
Old 11-08-2002, 11:51 PM   #5
flyin99
creator of kong
flyin99's Avatar
most double pumpers are dual feed......that means it has 2 fuel inlets..I know you have seen those chrome lines that go to the front and back bowls on the carbs.........that is dual feed........a quadrajet would be a single feed.......just has the one fuel inlet.........the Holley 6210 and a few other quad replacements are double pumpers, but have a single inlet, for ease of use and fit.........as for size.800 should be fine.........mine is a 750 and I have pretty much the same thing as you, except Merlin heads on mine ....hope this helps
As far as intakes....spread bore is the pattern for carbs, such as a quad..small primaries and large secondaries...........all you need is a square bore for a Dbl. pumper holley..........the oval/square port thing, depends on what heads you have.............
flyin99 is offline   Reply With Quote
Old 11-09-2002, 01:14 AM   #6
bigjimzlll
bigjimzlll's Avatar
Id do the double pumper...I used to have a 780...mechanical secondary..very nice..just a little tricky to fine tune
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-09-2002, 01:27 AM   #7
nate68
Holley Double Pumper if you really dont care about mileage. can i borrow it when i go to the track?
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 11-09-2002, 03:36 AM   #8
Hooter
My other Love
Hooter's Avatar
holley double pumper is the way to go!
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-09-2002, 09:48 AM   #9
Randy70C-10
Randy70C-10's Avatar
Sorry, I voted for "Stop asking questions". There wasn't a "Dominator" option. It's the best carburetor I've ran by far.
Randy70C-10 is offline   Reply With Quote
Old 11-09-2002, 12:13 PM   #10
crazy longhorn
Randy, thats a cool "carb spacer" you have under that dominator
Old 11-11-2002, 07:58 PM   #11
Randy70C-10
Thanks! You won't see another one like it. Nobody makes a carb-to-blower plate for a single dominator. That one was milled by my friend "Bob Manning" of Bobs blower drives. He did the fuel lines and distribution block as well.
