06-22-2008, 06:54 PM | #1 |
what carb?
my reman 4 bbl qjet carb is not cutting it truck keeps flooding out i was thinking about an edelbrock somewhere around 500cfm its going on a 305
06-22-2008, 07:06 PM | #2 |
Re: what carb?
I'd have a tendency to look at the fuel pressure and the float adjustment before giving up. I'm confident you can make what you have work...my $.02.
06-22-2008, 08:16 PM | #3 | |
Son of a gun
Re: what carb?
lower the float level. It may just be some trash under the needle valve.
Bill BEATERS ARE NEATER |
06-22-2008, 08:47 PM | #4 |
Re: what carb?
how do i do that? carb is new fuel is clean going though filter
06-22-2008, 11:37 PM | #5 |
Son of a gun
Re: what carb?
in a nut shell...
Take the top off of the carb, hold gently on the needle, and GENTLY press down on the float. There is a lot more to it then that...but the learning curve is steep. Do it once, and it'll be easy as pie after that. Study the info in these links: http://www.florida4x4.com/tech/quadr...d.com/Quad.htm http://www.florida4x4.com/tech/quadrajet/qjtshoot.pdf http://www.florida4x4.com/tech/quadrajet/qtune.pdf
06-23-2008, 09:14 AM | #6 |
Re: what carb?
I agree.That carb should work & is the best carb. for that engine. Try this trick. If a piece of dirt got into the needle & seat this will clear it out.
Clamp a vice grip on the rubber fuel line to block the flow of gas. Start the engine & run it till it dies or almost dies. Remove the pliers & restart the engine. If it doesn't work the first time try it again. If it still doesn't work you will have to go into it like the guys said. |
06-23-2008, 09:48 AM | #7 |
Re: what carb?
Talked a bit with him last night in chat - my recommendation was to get an overhaul kit and have a local shop replace the needle/seat and adjust the float.
06-23-2008, 11:07 AM | #8 |
Re: what carb?
Good advise Bill. He should try my tech tip first. I,ve saved many a carb doing that. Sometimes changing the filter will let a small particle get in the needle & seat. Sometimes these paper filters can give off a little fibre when new.
06-23-2008, 04:50 PM | #9 |
Re: what carb?
advance is exchanging the carb for my it was 2 months out of warranty but they doing ti anyway
06-24-2008, 12:43 AM | #10 |
10/30/19
Re: what carb?
Hey Dave,I've heard it that the reman carbs sit on the self awhile and the seals,gaskets dry out and it takes a couple of tries to get a fairly newer rebuilt carb.
Fight the good fight, finish the race, keep the faith |
06-24-2008, 08:16 AM | #11 |
Re: what carb?
yeah i had the carb a year before i installed it it might have got roughed around once to yeah
06-24-2008, 09:08 AM | #12 |
Re: what carb?
About half the rebuilt carbs you get from the part stores aren't any good.
06-24-2008, 08:29 PM | #13 |
Re: what carb?
well the guy that tuned the the truck said when he adjusted the left screw it made a differenace and the right one did not mak nay differences
