Anyone put a Ford 9" Rear in their C10?
I have a Posi disc brake Ford 9" laying around that I am considering putting in my 67. Anybody done the swap or have any suggestions or pointers?
Joe |
454 MAKES IT ROAR
Re: Anyone put a Ford 9" Rear in their C10?
Did you say the "F" word? and in a Chevy. tut,tut,tut.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
![]() Join Date: Aug 2005
just did it. Some ECE saddles makes it an easy swap. I used a disc rear from a 75 lincoln. All I need do now is see if I switch the parking brake cables from my 12 bolt and have the drive shaft shortened.
I plan on doing this exact swap someday...is there a build thread on it?
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
![]() Join Date: Jan 2008
I have one in mine.I'm Chevy to the core,but it's hard to beat the 9" for durability,availability of parts,and easy to change out chunks for different gear ratios etc. I've got 3:70 gears,Auburn pro-series posi,Moser 31 spline axles,Strange nodular center,Aerospace rear disc brakes,and a billet steel yoke.So far,I've never had a problem.
![]() Join Date: Apr 2008
My buddy did this and they make a kit for our trucks to make it super easy iI will ask him where he got it.
I have seen the ECE kit used with a 9-inch, thats what I would recommend
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
there aint many cars or lite trucks that you can name where a 9" hasnt been bolted into
Wow, looks like it's more popular than I thought! I found an article from classictrucks about this exact swap. They mentioned ECE as other members have as the source. The article says ECE even has a solution for the panhard bar with their super track kit.
Here's the link: http://www.classictrucks.com/tech/03...wap/index.html Here's what I found for the Super Track kit from ECE: http://earlyclassic.com/catalog.aspx?ProductId=1032
Joe Last edited by chevychase; 06-23-2008 at 07:53 PM. |
I always thought the GM 12-Bolt was a desirable unit? Is the version in our trucks not so good?
'67 C10 Short Stepside 5.0TPI/700R4 |
Registered Mail
axels are tapered and not enough splines = weak diff.
'67 chev 496, lwb to swb, bagged - pro street project |
12 bolts are great rear axles when compared to others...except the Ford 9"...they're almost bulletproof. There's a reason why most serious drag racers use them.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 06-24-2008 at 05:37 PM. |
I have one in my 1969. Just look for my post as it has pictures of it. I used the purch from a 12 bolt and a panhard bar bracket from a 12 bolt that came out of a 1965 chevy 1/2 ton.
Yep, it's hard to find a tougher rear end than the 9". Although I have seen a few of them torn up too. But not near as many as 12bolts. The 12 bolts are great rears until you start socking a lot of torque to them in a heavy vehicle.
Should be a fairly simple swap with the saddles and panhard bar kit from ECE. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
#15 |
I suppose I'm thinking of car applications where Nines are typically 28 spline small bearing versions.
'67 C10 Short Stepside 5.0TPI/700R4 Last edited by CochinoFilipino; 06-24-2008 at 03:32 PM. |
#16 |
Chevy nut
I used one in the Pinto drag car I had. 383 stroker...5 speed...9 in with 4:56's.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
#17 |
I'm a poor spectator
I'll be putting a 31 spline 9 inch in my blazer someday, the 12 bolt in it has been a lot of trouble.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
