Old 06-24-2008, 08:48 PM   #1
lks dcvn
lks dcvn's Avatar
Windows don't up roll up/down easy - need input please
Bought a project truck last winter and it has all new window felts, rubber, etc. in the cab - and especially the doors.
It is very difficult to roll the windows up or down...as in feels like it will break the regulator (or the glass)
I took off the door panel and sprayed the track down with White Lithium Grease - no luck...didn't change a thing. Not sure where it is sticking - appears to be the vertical track that the windows slide down/up (not the horizontal track the arms slide across)
Anybody have any tips/tricks to get these things rolling down a little better - instead of looking for older, beat up doors.
Thx!
lks dcvn is offline   Reply With Quote
Old 06-24-2008, 09:36 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Windows don't up roll up/down easy - need input please
Most time the problem that you are discribing turns out to be the division bar felts. As the window gets rolled up the felt slides up with the window inside the track and pinches the glass and sill. That is where I would start. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-24-2008, 10:08 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I had the same problem.I used some silicone spray lube(ever play Foosball?) on the felts and could not believe the difference.I also had problems with my Dodge Dakota power windows.I thought the morotr was going.Same thing solved that too.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-24-2008, 10:14 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I agree with the Silicone spray also...
I did the same on my truck. Put new felt and rubber kit. Sprayed with silicone and I also used WD40 on all the pivot points of the window regulator asm.
Lithium grease is okay for lubing sliding surfaces where the grease can be worked in, but the joints in those window regulators are pretty tight. WD40 penetrates the tighter areas.
68gmsee is offline   Reply With Quote
Old 06-25-2008, 10:55 AM   #5
lks dcvn
lks dcvn's Avatar
Did you guys spray all the felts (pictured below) with silicone spay or just some of them?
Making a pit stop on the way home to pick some up...I may just use PB Blaster on the arms since I have that at home (instead of WD40).
Thanks for the response!
Old 06-25-2008, 10:56 AM   #6
lks dcvn
lks dcvn's Avatar
Forgot the pic
Old 06-25-2008, 11:06 AM   #7
Classic Heartbeat
Silicone spray lube will only work if your weather-strip isn't coming loose from the channel and will only be temporary at best. The only place it will help is if you spray it in the division bar felt. That is the only felt besides the squeegee and fuzzies that stays in contact with the glass and sash at all times. The division bar is track designed to keep your window from moving around on the wheels, or flopping back and forth in the window gap. It should be against the glass but not so snug that it holds onto the window or sash. Is the division bar felt new? WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 06-25-2008, 01:09 PM   #8
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
I had the same problem with mine after i put new rubber and felt in. It was the division bar. I loosened the screws at the bottom of the bar *the two at the bottom of the puple line* and pushed it forward about 1/8 inch. That fixed it. It was just too tight.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 06-25-2008, 01:23 PM   #9
lks dcvn
lks dcvn's Avatar
forward as toward the front of the truck (hinges on the door) - correct?
Old 06-25-2008, 01:57 PM   #10
jayharrell
jayharrell's Avatar
correct. Loosen those two screws, and the 3 along the top front of the door that hold in the vent window, 3 smalle flat head screws.
Roll the window up and down, and that should give it the slack it need. Then while the window was down, i just tightened everything back up where it is.
You might have to move the braket for the window channel a bit as well *green line*.
00 S10 2.2 Vin5
Old 06-25-2008, 05:34 PM   #11
68gmsee
Active Member
68gmsee's Avatar
I used the WD40 on all the pivot points. Soaked it in pretty good as I worked the window up and down.
Surprisingly enough, I don't care for PB blaster that much. Everyone was raving about it so I bought a couple of cans. I've used it on some of the rusted bolts and nuts and it wasn't any better than penetrating oil or spray oil -at least from my viewpoint.
Old 06-25-2008, 08:13 PM   #12
Brock
upgrading to an older model
Brock's Avatar
Mine are/were hard to get up and down as well...I promise you it aint the felts since they are gone!!! My problem was that the "sprocket" on the regulator and/or the "gear" are just flat wore out. I replaced the driver's side and it works like a dream even without the felts. I didn't realize the same problem existed on the passenger until yesterday.
Side note...PB Blaster STINKS!!! Literally it smells like ... well my nephew calls it Panther Pi$$ for a reason.
68 stepside, short-box, multi-colored (for now)
Brock is offline   Reply With Quote
Old 06-25-2008, 09:46 PM   #13
leddzepp
Moderator
leddzepp's Avatar
I replaced the regulators on my doors and they work just like new.
Old 06-25-2008, 09:46 PM   #14
leddzepp
Moderator
leddzepp's Avatar
