Old 06-29-2008, 11:27 AM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
1972 Emission Hose Routing
Can anyone send me a picture or a link to a diagram for the emission hose routing on a 72 C10 350-4 AT. I'm trying to get it inspected and while it is exempt from testing the Inspector wants all the hoses routed correctly, al thought I doubt he really know where they go. I have searched the archive and found nothing. It does have the TSC on it. The hoses I really need cleared up are the 5/32 hoses from the evap can to the Carb, TSC or where ever it goes and how the tsc is connect into the system.
Thanks,
Old 06-29-2008, 12:08 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 1972 Emission Hose Routing
if it is exempt from testing... then why is he making you do this?
Old 06-29-2008, 12:17 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
He is being a male appendage. He's new at his job and his reasoning is that while it is exempt from all emission testing, all equipment must be in place and functioning. The only thing there is is hoses and that TSC valve and a evap container so its got to be connected right. I would have gone somewhere else but he got the inspection failure in the system so I have to fix it.
Old 06-29-2008, 01:53 PM   #4
Longhorn Man
I hate to agree with some being a male appendage ( by the way!) but he is technicly right. No smog items are to be removed on any and all vehicles operated on a public road... per federeal law.
I wish I could give you some assistance, but all that crap has been removed off my 72.
Old 06-29-2008, 05:59 PM   #5
71 super
71 super's Avatar
One hose the 3/8 connects to the port at the PCV line with a "T" connector- it ties into the PCV system, the second smaller hose connects to the ported vac source located at the front of the carb roughly half way up next to the throttle arm/pump. The TCS takes vac from port vac advance hooks to lower right near mixture screw on pass side- should have short hose from this port to TCS module port located to the front, the top porton tcs connects to the port on the vac advance. The breather hose should attach to the far right vac port that points to the fender should be a long vac fitting located in middle of the choke assembly. If this needs pics let me know and I will try. Hope it helps.
71 super is offline   Reply With Quote
Old 06-29-2008, 07:51 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
My advice: Move to Oklahoma and never worry about inspections again!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 06-29-2008, 08:02 PM   #7
grayw0lf
You could probably just route the hoses to endless places. You could probably route the hoses from the canister around & back to themselves. You could also probably seal up the EGR valve to where its more or less, blocked off.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-29-2008, 08:42 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
Here,see if these help,if you can read then (cheap scanner). Plus you'll have to turn your monitor upside-down ,sorry.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-29-2008, 08:42 PM   #9
JimKshortstep4x4
Here is a picture of the schematic for the emissions with the hose routing. Hopefully you can see what you need to see.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-29-2008, 08:27 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
Thanks for the routing info 71 super, if you could send a picture to info@thoroco.com it would be great.
Oddly enough greywolf there is no EGR and he said nothing about it having to have one, he just saw the TSC was disconnected and the evap hose was broken off. I really don't think he knew what he was looking at and it would be my luck he'd look it up for my re-inspections. The truck is 10 years older than he is so I can't imagine he's seen alot of 72's.
But as longhornman says it is federal law that if it had it it needs to be present.
Old 06-29-2008, 09:08 PM   #11
Longhorn Man
As for the EGR comment... these trucks never had them.
Old 06-29-2008, 09:22 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
great thanks, i think I can figure it out with these. My repro book doesn't have half this stuff in it and the pictures are very dark
