07-03-2008, 03:45 PM | #1 |
Serpentine questions
I have a few questions about my serpentine setup which came off a 88 s-10.
#1 Do I need to have the idler that goes where the arrow is pointing? If so where can I get one? #2 How do I route the belt on this set-up? And does anyone have a part number that will work? I bought the belt for a 88 s-10 and it was way too short. Thank you for looking. If it wasnt for this website, I would have quit a long time ago.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
07-03-2008, 03:59 PM | #2 |
Re: Serpentine questions
You do not need an extra idler pulley.
Look at the diagrams part way do this page for routing: http://www.2carpros.com/forum/1990-c...-vt132692.html For my belt I just ran a string and measured. Then got a belt that length. There are so many different serp bracket setups that its hard to do part numbers. What water pump are you using?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 07-03-2008 at 05:17 PM. |
07-03-2008, 05:03 PM | #3 |
Lemme show you something!!
When I did mine- I wasn't sure if I needed that pulley or not. The GMPP kit comes with it- so I figured I'd better get it. I got mine from the local stealership but the link below has them for about 10 bucks less. If you do use this idler- get a Gates #K060970 belt. If you opt not to use it.....I am no help to you, cause I don't know what the correct belt would be.
http://www.tpiparts.net/inc/sdetail/399
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
07-04-2008, 09:18 AM | #4 | |
07-11-2008, 11:36 AM | #5 |
jackyl9999, I'm also in the process of installing a serpentine system in my truck. What A/C compressor are you using with your setup?
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
07-12-2008, 09:59 PM | #6 |
http://www.oldairproducts.com/catalo...00000_69000003I got it from old aire. They offer them for a serpentine.
07-14-2008, 07:38 AM | #7 |
Thanks for the 411
07-03-2008, 06:47 PM | #8 |
Hollister Road Co.
I think you could get away with out it but with it you have that much more belt contact with the pulley. If you didn't have A/C I'd go without. I have the same setup on mine and I used the idler. I used a K060935 belt and then a 940 which is 1/2 shorter than a 935
07-04-2008, 08:58 AM | #9 |
MY EX DRIVES A BROOM
good info
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
