Brake booster
Hi all, I have a question. I am trying to get my 72 K20 on the road after way to long. Is there any way to check the brake booster off of the vehicle? It is the original and has been not drivable for some time,in fact the motor was pulled when I bought it so I don't know it it worked when I got it. Thanks.
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi. |
Re: Brake booster
If you have a vacuum pump then you can check the booster for leaks. Vacuum leaks are the most common problem so checking for leaks would be a good test.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: Brake booster
Thanks for the reply. I tried that and it didn't work, tried it on one that just came off of a truck so I believe it is good and it didn't work on that one either. Checked the local supply house and they actually have one in stock for $100. Might just pick it up to be safe.
