Old or new gauge cluster
I am about finished with installing a heidt's IFS, power steering, and a new 700R4 transmission. I have also installed a new flaming river steering column and will soon have a 70 El Camino 12 bolt 3:73 Posi rear end to install. Now I am thinking about the guages, since they have never really worked. Now I am trying to decide if I want to rebuild the old guages or go with a new set. What do you all think? I would like to see some photos of some gauges to get some ideas. Any type that works well and not to hard to install? Here is what's completed so far..
Yellow truck club
Re: Old or new gauge cluster
Auto meter gauges
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
classic instruments
Gene Sharp |
Classic Instruments---X2
Jeff |
Daytona gauges with homebuilt insert:
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, Last edited by orgalmeister; 07-05-2008 at 08:59 AM. Reason: spelling |
#7 | |
Yellow truck club
I like that look .....
#8 | |
![]() Quote:
Dr. Frankenstein
im going with restoring the Original
![]() Nice looking setup you got there dwcsr!
I Wanna Go Fast!! |
I know the orig gauges are not that revealing, are rather small and hard to read and may not be that accurate either. I was thinking of retaining the original setup but then having another set of better gauges off to the side somewhere, if this is even possible.
![]() Last edited by dragonstruck; 09-10-2008 at 07:21 AM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Billet insert and vdo guages..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
We recently Purchased at complete "Direct Replacement" from nordskogperformance.com , a DP7003B Dash Panel for a 1957 Chevy Truck.
We attempted to install it, but the Panel's components will push against the Panel "Glass" if we use the spacers provided. Also, if spacers are used to maintain a space between the panel's components and the "Glass", not only will the glass be unsecured, but this will allow airborne dust to collect on and between a the panel surface and on the inside of the panel glass. The Dash has a part # 51-41007 Rev B on it. Are we missing Parts? Are there assembly Drawings/ Instructions available? Thanks, Frank |
#13 | |
Yellow truck club
Hollister Road Co.
I brought a stock gauge setup over to a local pin stripper and got this done for $75. I think the original design is the best layout. With a little creativity you can make them look great.
#15 |
snap that original modified is awsome. I've always prefered original. Just think how rare they will be in 20 years... I had my originals rebuilt for about 100 bucks more than new ones definatly worth the investment
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#16 |
Mark me as X4 on the Classic instruments panel. That would cause double takes all day long and still holds the appearance of the original gage panel.
Second I think I like the two gage panel that Orgalmeister showed us. Third choice would be the restored original gages as I have always thought they were a good looking set ever since I had a 57 Panel way back when. Last edited by mr48chev; 07-14-2008 at 12:43 AM. |
