07-08-2008, 01:55 PM | #1 |
Sofa King. We, Todd, Ed.
Help! Front drive shaft keeps "falling" out.
OK this is pissing me off. The bolts that bolt the CV yoke to the transfer case keep backing out. Ive tried red, blue and green lock tight. Last time out, I forgot to check the bolts, it looks like two backed all the way out then, of course the remaining two sheared off. I've been using u-joint strap bolts because they are the same fine thread and have the smaller bolt head. Am I missing something?
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 07-08-2008 at 01:57 PM. |
07-08-2008, 02:00 PM | #2 |
Moderator
Re: Help! Front drive shaft keeps "falling" out.
I had that problem before. I could not get the bolts to hold at all. I wound up cleaning the bolt holes and bolts with simple green and then soap and water. It held for me then. Apparently I got grease in there and it wouldn't hold.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
07-08-2008, 02:32 PM | #3 |
Clean the bolt and the threads with brake parts cleaner. Make sure they are dry - no grease, no oil, clean... Then blue locktite the bolts and torque to spec.
07-08-2008, 08:14 PM | #4 |
Above advice should work, but you could make some sheetmetal tabs, like used on exhaust manifolds
07-08-2008, 08:17 PM | #5 |
It is a greasy mess down there. Simple enough to clean it. Thanks!!
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
07-09-2008, 06:09 AM | #6 |
What...no pics?
I like the metal tab idea myself, then you'd be sure. |
07-09-2008, 11:04 AM | #7 |
Do you have to add 10 percent of the torque value when adding a solution of liquid?
07-09-2008, 02:19 PM | #8 |
Jonnyw. There Is A Number Of Things That Can Contribute To Your Problem. You Have Already Been Told A Couple Of Things. If Those Dont Work. Check To See If Your Yokes Are Binding Up When You Put Twist On Your Suspention. Looking At Some Of Your Pictures I Bet The U-joint And Yokes Are Binding Causing Stress On The Straps And Bolts. You May Be Able To Do A Little Grinding. Or The More Expensive Route , Bigger Joints. You Probaly Have A 1350 Joint. If So Go To A 1410. I Hope The Info Helps. Looks As Though You Have Fun With Your Ride, I Can Apreciate That, Bighead
07-09-2008, 07:14 PM | #9 |
the pollock
i had that issue also i used a bore brush to a 380 pistol on a cleaning rod with my drill, then sijmmplegreen ord driveway cleaner ...
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
