07-12-2008, 12:58 AM | #1 |
Acetylene torch. Who has one?
I need to melt a couple of pistons to fell an exhaust crossover in the cylinder heads. I preffer to do as much work as possible without depending on the machine shops. Anyway, I might buy a torch set up. Who has one and how often do you use it? I am trying to see what else I can use it for to justify a purchase.
07-12-2008, 01:07 AM | #2 |
I have a radical idea!
Re: Acetylene torch. Who has one?
I have one that I use regularly. I use it mainly to cut up scrap for salvage, and to cut off stuff on junkers that I'm parting out/scrapping. I've used to heat up gets out broken studs and bolts, to heat up parts that have to be pressed in, to braze, and if you change the tips you can weld with it. It also works well to do a poor man's drop kit! This is precisely how I lowered my beater!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
07-12-2008, 01:11 AM | #3 |
Gone to greener pastures
I don't use mine real often, but the ol' "blue tip wrench" sure comes in handy when you need it.
Once you make the initial outlay, it's not all that expensive. I'm using as "S" oxygen and a "WS" acetylene sized tanks. (I think. I'm too lazy to go out to the garage to check) They're a little bigger than what I've seen others use in their garages/home shops; but to me, it means fewer trips to the welding supply. That's just my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
07-12-2008, 01:18 AM | #4 |
Never Ending Projects
I have an oxy/acy rig, plus two Migs and a plasma cutter. Each one has their own purpose and sometimes one won't work when the other will.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-12-2008, 09:16 AM | #5 |
If you do buy one, get a good one, not a piece of junk. I personally like Smith, but a Victor of Purox are equally as good. I got both a good size Plasma and a Smith Torch outfit, unlike some say that the plasma will replace the torch for cutting, I still use it alot for that purpose, mainly because I cut alot of steel 1.5" thick and thicker. But for under that I use the Plasma.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
07-12-2008, 10:53 AM | #6 |
to block a heat crossover i've always just used jbweld in the manifold ports never had an issue in 40years of doing it that way never needed a torch to do it
but a good set of torches is a great tool to have i too have always prefered smiths and i have always used the minitorch 10X more than the big ones
07-12-2008, 11:27 AM | #7 |
I spent a summer doing tear-downs at an engine shop.... lol that was fun
If not for the ole Acy torch I would STILL be trying to get oil galley plugs out of some of those 250k mile 30 years-since-last-rebuild motors. One of the most useful tools I had. I've wanted to buy one ever since
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
07-12-2008, 11:58 AM | #8 |
Personally if I could I would get one. We have a couple at work and it seems like I always have to run to the shop to use the thing. If you added up all the gas I use going to the shop to use the torch, I could have probably bought a good one a couple of times over. They are handy for more things than you can count.
Just my opinion
1969 4x4 Nothing beats a good rock drill and some dynamite |
07-12-2008, 11:53 AM | #9 |
Chevy nut
I use mine all the time. Heating and cutting. 3 favorite tools...torch, Sawzall and BFH.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
