converting a longbed to a short bed
Ive seen people do this but I dont know how to do this. I have to replace all the rear corssmembers do to rust and I am going to replace the rear end, springs and relocate the shocks so i figure I may as well shorten it up. Im going to try to find a short box instead of cutting up my long box. How and where do you shorten the frame to convert it?
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
Daily Driver
Re: converting a longbed to a short bed
nitrous...the equal opportunity destroyer. |
Does the 12" have to come out fomr under the cab" or can it come out from right behind the cab?
you need to come south and get a rust free short frame. I don't have one at the moment but I'm sure I can find you one!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I'm taking mine out from behind the cab. I am building a 4 link so I see no reason to cut the usual section under the frame. Also the section I am cutting is the wide section of the frame above the axle doing that I will gain about 2" on each side for more clearance. Just my .02
I'm just going to pull the cab and take it out from there. A local blasting shop will blast and powder coat my frame for $300.
#7 | |
![]() Join Date: Jul 2007
As I read your posts I keep thinking what's ahead for me with my C10. Although my C10 is already a shortbed my plans to do a back half, narrowed 9" F**d rear end with ladder bar setup & "alter" the wheelbase by moving the rear axle 5" forward I will be watching this thread closely. Good luck, take your time and post lots of pictures.
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? |
Damn, I am I wish I could find that here!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
